1989 Safari GLX Primary Clutch - Snowmobile Forum: Your #1 Snowmobile Forum
Old 08-11-2012, 11:25 AM   #1 (permalink)
Does anyone know where I could find a primary cluch for my Safari? All my google searches are coming up blank. Thanks.
jjm152 is offline   Reply With Quote
Old 08-11-2012, 01:16 PM   #2 (permalink)
Or if someone could tell me if there are other clutches that would fit that sled...Also, does anyone know how much play there should be in the secondary clutch? There seems to be a ton of play in mine...like 90 degrees side to side..
Old 08-12-2012, 08:00 AM   #3 (permalink)
Any TRA clutch from a similar sized engine will work.
That secondary is probably in need of replacement.
Old 08-12-2012, 10:04 AM   #4 (permalink)
The clutch only has 3000 miles on it...do they wear out that quick?
Old 08-12-2012, 01:40 PM   #5 (permalink)
They are splined, and if the bolt was loose, they will wear the splines and have a ton of play. eBay probably has a ton of them.
1999 Ski Doo Grand Touring
Old 08-12-2012, 05:45 PM   #6 (permalink)
aduck's Avatar
I have both clutches off a 90 583 if it helps. Both were in gods working order 2 years ago haven't ben used since
Sent from my M865 using Snowmobile.com App
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 08-13-2012, 05:36 AM   #7 (permalink)
Would those fit on the Safari GLX 477 (I think). I'm pretty new at this snowmobile thing so bear with me!
