07-11-2012, 12:41 PM
#21 (permalink)
Originally Posted by smallengineguy
You need to change the chaincase to have reverse. Elec start is very complicated.
Very interesting! Maybe you know from what model it is seutable for me? it cause many changes in trasmission? or just replase one with another one?
i'd like to have reverse very much!
07-12-2012, 06:13 AM
#22 (permalink)
Any grand touring sled from your year will work. You replace it with another one.
1999 Ski Doo Grand Touring
07-12-2012, 07:11 PM
#23 (permalink)
i tried to find a ski-doo chain case- but i did not succeed...Only ski-doo i should ask or another will seut too?
07-12-2012, 07:30 PM
#24 (permalink)
I found these on eBay SKI DOO GRAND TOURING 500 OEM Reverse Chain Case #63B80A/ According to fotos- it is whay i need!
Thank you, smallengineguy!
07-12-2012, 09:33 PM
#25 (permalink)
Try Dennis Kirk they have a lot of snowmobile parts and I have had good luck with them. Drain all fluids and add new, and you should clean the clutches, and the carbs.
07-12-2012, 11:08 PM
#26 (permalink)
in all fluids was water, in carbs water, dust, corrosion, some white mud and so on.... i have only fotos- but i don t know how to describe them in english =)
oil (water) from chain case
Reason: added fotos
07-13-2012, 09:54 AM
#28 (permalink)
Try soaking the carbs in gas, I have done that and it works very well. As for the chain case, as long as you get all the oil and water out and add fresh it shouild be fine.
07-15-2012, 04:00 AM
#29 (permalink)
maybe anybody knows.... what comptession must have Rotax 467 (i bought used on eBay) without rotary valve? i'd like to measure it and decide to repare, or to use as it is.
07-16-2012, 07:40 AM
#30 (permalink)
Any reading above 120psi and within 10% of the other is good.
07-16-2012, 10:32 PM
#31 (permalink)
how to put flywheel with magneto and variator from my engine's cranckshaft?
07-17-2012, 06:25 AM
#32 (permalink)
Is it the same engine type? You need a flywheel puller to take the flywheel off.
07-20-2012, 10:01 PM
#33 (permalink)
man i have see carbs like that on a 470 my buddys i have been working on that POS for a long time we cleaned the carbs and in taring them down they looked like that and after looking at them more there was a crack on one were some one put jb weld in side the bowl yea i know great to see that haha not anyways we just bot new carbs and ran great last year
07-22-2012, 11:08 PM
#35 (permalink)
I Have searched for 470 motors before and they are hard to find in my area out of a sled running, if i where u I would go buy a 470 sled with a blown track or other problems with a running motor, and just pull the engine and swap it. if it was full of water and sat then I would have to assume that your crank is rusty aswell as all the bearings and everything else, and for Electric start and reverse I would personally just go buy a sled with the 2 options already on it it is alot easyer and alot less hassle
07-22-2012, 11:15 PM
#36 (permalink)
I boughy all sled for 120 dollars, and bought already parts for it on 600 dollars
07-22-2012, 11:29 PM
#37 (permalink)
i paid 100 dollars for a sled with a blown motor, didnt turn over and the insides where completly destroyed. Then i found a guy with the same sled with a blown track for 300 dollars in running condition just to give you an idea, it would be much cheaper to get a hole sled, but since you have spend the cash to get parts I wish you the best my friend.
07-22-2012, 11:42 PM
#38 (permalink)
in russia i was told, that only Cilinder head will cost over 600 dollasrs! in CA it is much cheaper and easier. I tried very much! Thanks!
09-24-2012, 10:16 PM
#39 (permalink)
Hi all! Can anybody tell me- i'm going to assemble the older motor - will it work with my electronic?
01-04-2013, 12:29 PM
#40 (permalink)
Hi.
Happy new year!!!
I did not have tube going from cilinder head.
i've found some videos and i see: only ONE tube is going from head, then it is 3 way splitter. one tube is going to the top of the coolant tank and another is going to the radiator. is it the simple 3 way splitter or it is someting else?
i already bought:
engine 1989year 467type without any electrics
head for my engine
crankshaft for my engine
valve and oil pump
head for not my engine
pistons
cilinders.
And only a few week ago a finished to create a home for my sled. till that time he lives outdoors.
And still did nothing for the sled. Leek of time and place. now a have a place. I'm going to California this january and going to bring missing parts. then i'll try to asemble smth =)
Reason: add foto
