mach 1 instrument panel and head light out - Snowmobile Forum: Your #1 Snowmobile Forum
Old 05-15-2012, 02:10 PM   #1 (permalink)
hey guys i have a 97 mach 1 and my dash pannel and head light keep going out but some times pop back on any idea on how to fix this thanks
kevo129 is offline   Reply With Quote
Old 05-15-2012, 07:01 PM   #2 (permalink)
aduck's Avatar
Check your connections and ground then move to looking at writes for rub tHroughs
Bout if put money in a lose connection our bad ground.
Hope that helps
Sent from my M865 using Snowmobile.com App
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 05-15-2012, 10:58 PM   #3 (permalink)
ride till your broke
Renagade's Avatar
Hope that helps
id have to agree!!!
check every connection!! ull find it!!
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 05-16-2012, 04:01 AM   #4 (permalink)
The plugs at the bottom of the hood near the hinge are usually the culprit.
1999 Ski Doo Grand Touring
Old 05-16-2012, 12:28 PM   #5 (permalink)
thanks guys gunna give it a shot
Old 05-16-2012, 12:55 PM   #6 (permalink)
well i found the problem there is rubbing in the wires but the rubbing is under the motor is there a prefered method to get the harness out for rewireing with out takeing half the sled apart? again thanks for helping me pin point the issue guys sled has been so reliable this is the first time ive really had to tinker with it
Old 05-16-2012, 03:55 PM   #7 (permalink)
hey guys there is a red wire with green stripe that is attached to the harness with a u hook on it is that a ground wire?
Old 05-17-2012, 04:01 AM   #8 (permalink)
I would try to get the harness all the way out. That was a known issue with those sleds, and you should try to reroute it somewhere else.
Old 05-17-2012, 07:50 AM   #9 (permalink)
Renagade's Avatar
my formula has same color wire,
its just hanging there too??
but i have no problems
current sleds
04 rev800ho gade
95 formulaIII 600
Old 05-17-2012, 08:11 AM   #10 (permalink)
davidnnoah's Avatar
The red/green wire comes from the start switch and goes to the optional starter. You may wish to cap this if it's been left bare.
You might want to pull the pipes to gain better access to the wiring in the front there. I don't see a need to reroute that harness. Just pull it out so you can make repairs and tie it back in place.
In 98, the cdi and v-reg were moved to the belly along with all the ignition wiring that goes with them. This is where the infamous chafing problems began causing no spark. Your 97 just has the few lighting/gauge wires under there and as long as they are protected with conduit and tied off, you'll be fine.
Take this opportunity to clean all those connections and lube them with silicone grease. Do it once and forget about them. Good luck.
http://webmn.alsa.org/site/TR/Rides/...nal&fr_id=8590
David H
Excelsior, MN
98 F3 600
97 Mach 1 700
95 MX 470
davidnnoah is offline   Reply With Quote
Old 05-17-2012, 08:16 AM   #11 (permalink)
Renagade's Avatar
wow, never thought of that. duh.
current sleds
04 rev800ho gade
95 formulaIII 600
Old 05-18-2012, 08:38 AM   #12 (permalink)
Thanks guys as i was doing that i shut down shop for the night and came out to the garage to find a pool of fuel on the ground while the fuel was shut off so im thinking i got a leak from the fuel tank its self or as i read in the shop man that i might have a fuel pump diapram leak none of the fuel lines show any type of signs of leaking but i got fuel driping from the bottom so now i need to figure out how to see in better detail where its coming from good thing i got months before the snow returns
Old 05-18-2012, 08:39 AM   #13 (permalink)
thanks after reading the shop manual i found the use of that wire so im going to cap it just for precautions
Old 05-18-2012, 08:55 AM   #14 (permalink)
davidnnoah's Avatar
My 95 dumped a ton of fuel one evening, right in front of us while we were having cocktails in the yard. I had just topped off the tank that morning. A small temp' change appeared to be the cause. I no longer fill the tanks to the top. Just a thought.
David H
Excelsior, MN
98 F3 600
97 Mach 1 700
95 MX 470
Old 05-18-2012, 11:07 AM   #15 (permalink)
Renagade's Avatar
good thought!!!
this is the time of year with all the temp changes
that pressure builds up in tank. my gade has a valve that kinda
whistles to let out pressure. i usually am out in shop, so once
in a while i crack the caps loose, im amased on the pressure
that comes out.
even with the fuel drained from tank!!!
current sleds
04 rev800ho gade
95 formulaIII 600
