Hello, does anyone have part # that will replace oem fuel pump for a 1999 380 touring?
My local stores say that it is obsolete. OEM part # is 403801000.
Even if I had to mount a replacement one in a different way.
Do you have a picture of it? It's probably a Mikuni and you can buy them aftermarket.
__________________ 1992 Ski Doo Mach 1 (SC-10/2 suspended) March '07 SF.com Sled of the Month! (Lost in fire 4-13)
1992 Ski Doo Mach 1 original 2006 Ski Doo MXZ 500SS
You should still be able to make any fuel pump work. There really isn't much different with fuel pumps besides some are for one cylider, two cylinder, and triples.
Hello, thanks for the reply.
I have found aftermarket pumps with the same inlets/outlets but they pump 32 liters or 64 liters per (hour?)
Which one would work?
Hello, and thanks for the reply's.
It was not the pump.
I thought it was the pump because when I rolled the engine over I could see that gas was not being pumped to the carbs.
This morning I was tinkering with it and found that the pump worked but would not pump gas to the carbs. So I drained the carbs bowls and rolled her over and the pump then filled the lines and then the bowls and she fired up and ran normally.
