335cc Rotax Sled Engine - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 28 (permalink) Old 04-08-2011, 10:11 PM Thread Starter
Hey guys im really new to the whole snowmobile stuff, but i found this engine on craigslist and wanted to know if it was worth it.
2-Cycle motor 335cc single cylinder. ROTAX!
this is the link to the add.
its missing the carb and the exhaust so i was thinking of making it a new exhaust and trying to fit an old briggs and stratton or honda carb on it.
edit: the 13hp briggs engines are rated at over 370cc. could one of these carburetors work??
Thanks
theconcept is offline
post #2 of 28 (permalink) Old 04-09-2011, 07:02 AM
What are you trying to do with it? The exhaust NEEDS to be tuned to the engine so it doesn't burn a piston down (2 strokes need backpressure provided by the exhaust). As far as the briggs carb, not sure on that!
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 28 (permalink) Old 04-09-2011, 12:05 PM Thread Starter
i wanted to put it onto a gokart so i thhought i would be able to throw any old exhaust on there, and a carb.
how much is the exhaust for this engine??
post #4 of 28 (permalink) Old 04-09-2011, 12:26 PM
69CRUZR's Avatar
You need to find a junk complete sled that you can take the whole engine with carbs and everything to make it run, plus then you can steal the chaincase off it and mount that right on your go kart to make it drive! Be suer to get both clutches!
1998 Polaris XC600 (with a XCR sleeper hood on it)
2006 Polaris Indy 500
1969 Chevy C10 "69CRUZR"
-383 stroker 450 hp 479 ft lbs of torque
2006 Chevy Colorado -daily driver
New Project Truck, this one for my Pops!
1953 GMC 5 Window Shortbox Stepside
Drivetrain: 2006 5.3 Liter v8 with 4l60e from an 06 Silverado.
Full IFS front suspension kit w/rack and pinion steering, and 4 link rear from TCI Enterprises.
69CRUZR is offline
post #5 of 28 (permalink) Old 04-10-2011, 07:05 AM
Where are you located? I've got a running Rotax 277 with exhaust, oil injection tank, etc, for $250.
1999 Ski Doo MXZ600
post #6 of 28 (permalink) Old 04-10-2011, 08:15 AM
Another problem with using a carb from something else on that engine is that the pulse line actually runs through the manifold rather than as an external line, so you would need a carb specific for that engine.
post #7 of 28 (permalink) Old 04-13-2011, 11:34 AM
Ski Doo Oly
EWerner's Avatar
The 335 was used by Ski Doo in the Olympiques from '70 through '72 and are bullet proof, run for ever engines. Used mufflers are hard to find but you can get a new one at: Vintage Snowmobiles | Vintage Snowmobile Parts | Snowmobile
The card is a Tillotson HR17C.
The 335e, electric start has an external coil as opposed to the internal coil of the non e model. In my opinion the external coil is more reliable.
The motor is designed for snowmobile use so running in a cart be sure to allow ample air flow to keep it cool.
EWerner is offline
post #8 of 28 (permalink) Old 04-15-2011, 07:12 PM Thread Starter
what does the lack of backpressure from the exhaust do to the engine??
edit: would an exhaust like this one work?? YAMAHA TRI Z EXHAUST PIPE AND SILENCER EXPANSION | eBay
post #9 of 28 (permalink) Old 04-15-2011, 09:25 PM
If there is no back pressure, it causes the exhaust side of the piston to get hot enough to melt and score up the piston/cylinder. That exhaust may work, but it's tuned to a 250. The best bet is one from a 335.
1999 Ski Doo MXZ600
post #10 of 28 (permalink) Old 04-16-2011, 02:13 PM Thread Starter
i found this carb on ebay. Its a mikuni brand snowmobile carb.
MIKUNI VM-30 Carburetor- Snomobile + Motorcycle + Cart | eBay
will that work on the rotax??
post #11 of 28 (permalink) Old 04-16-2011, 02:33 PM
It would work, but you will have to drill a hole into the base for a hose barb so you can add an external fuel pump too.
post #12 of 28 (permalink) Old 04-16-2011, 05:34 PM Thread Starter
im sorry but everything you said after it woulld work was japanese to me. LOL
post #13 of 28 (permalink) Old 04-16-2011, 05:37 PM Thread Starter
ok im starting to make sense of it, but what type of fuel pump would i need??
post #14 of 28 (permalink) Old 04-17-2011, 07:51 AM
A Mikuni square pump would work after you put the fitting into the engine base.
post #15 of 28 (permalink) Old 04-17-2011, 08:06 AM Thread Starter
wat does the pump do exactly and is it necessary??
post #16 of 28 (permalink) Old 04-17-2011, 08:13 AM
Yes, it will be necessary.
The original carb has the pump as part of the carb. A mikuni used a separate pump to fill the bowl.
If you take a look at the manifold on the engine, you will see a small hole just inside the right carb mount stud. This is the pulse line that runs the fuel pump. You will have to make an attachment place (hose barb in the base) for a pulse line for an external pump.
post #17 of 28 (permalink) Old 04-17-2011, 09:19 AM Thread Starter
how difficult is it to do this??
would one of you be so kind as to find me a square pump thatll work on ebay for cheap i dont know what im looking for so maybe one of you could help
post #18 of 28 (permalink) Old 04-17-2011, 11:36 AM
Mikuni Single Fuel Pump - DennisKirk.com
post #19 of 28 (permalink) Old 04-17-2011, 05:12 PM Thread Starter
also found this on craigslist. im thinking i should just go with this that way it has everything that i need right there.
1978/9 polaris Apollo 340
post #20 of 28 (permalink) Old 04-18-2011, 07:57 AM
I'd be concerned about there being no plugs in the heads and the top shroud missing.
With the plugs out, a lot of moisture can get into the engine and cause bearing damage.
