Rotary Valve Timing - Snowmobile Forum: Your #1 Snowmobile Forum
Old 02-02-2005, 02:10 PM   #1 (permalink)
Rotary Valve Timing
Does anyone have the numbers for a 99 mxz 500? I am putting it back together for a guy and his case has 2 scribed lines and a notch on the case. The 2 scribed lines are about 5 degrees and 7 degrees counter clockwise of the notch on the case. I alwasys used to use the notch on the case for a sea doo. I am thinking it needs to end up between the 2 scribed lines on this motor but I'd like to be sure.
Thanks
DonColliau is offline   Reply With Quote
Old 02-02-2005, 04:43 PM   #2 (permalink)
four gear pinned
sesnopro's Avatar
go to a dealer they will tell you ther specs.
http://www.hiperf.com/
Old 02-03-2005, 06:20 PM   #3 (permalink)
-Mag side piston at tdc
mag side rotary hole fully uncovered with the the rotary disc "just"under the mag rotary crankase opening.the pto side will be covered at this time.
You ll be ready to install the cover.Good luck.
HiOctane is offline   Reply With Quote
