Formula III brake problem - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 01-26-2011, 01:16 AM Thread Starter
I've been having problems with my brake locking up. The first time it happened, I checked the fluid level in the reservoir and it was low. I filled the reservoir and drove the sled all of 2 miles and it happened again. I let the sled sit overnight and drove away no problem. Made it about a mile and a half and again it locked up. Is there a way to adjust this brake? It seams as though even when it's in working order, it is very sensitive. Any ideas? Thanks!
adschemy1 is offline
post #2 of 11 (permalink) Old 01-26-2011, 06:52 AM
Trevor
YamahaSS440's Avatar
I don't know, but I swear all of them older ski doo brakes are problematic. My friends 95 Formula Z last year started on fire due to the brake locking up and sparking and igniting. Now, my other friends 1995 Formula Z is doing the same thing. Give the rotor a good check over and make sure nothing is leaking. I think there is a way to bleed air out of it also.
2009/2010 Miles:900
2010/2011 Miles:1300
2011/2012 Miles:530
2012/2013 Miles:1050
YamahaSS440 is offline
post #3 of 11 (permalink) Old 01-26-2011, 07:11 AM
ride till your broke
Renagade's Avatar
i had the same problem with my 95.
i ended up bleeding all old nasty brake fluid out,
and flushing system out.
havent had problems since.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e
Renagade is offline
post #4 of 11 (permalink) Old 01-26-2011, 11:06 AM Thread Starter
Sorry to sound stupid but i'm not very mechanical. How would I go about bleeding and flushing the brake line? Thanks again!
post #5 of 11 (permalink) Old 01-26-2011, 11:49 AM
Renagade's Avatar
hook a piece of clear nose to the bleeder on caliper.
then remove cap of mastercylinder, loosen bleeder.
then pump brakes slowly, make sure that master
doesnt run low while pumping. pump till clean
fluid gets into clear line. tighten bleeder and
remove hose, fill master to proper level.
make sure not to get any brake fluid on ANYTHING.
will do damage to plastics real quick.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e
Renagade is offline
post #6 of 11 (permalink) Old 01-26-2011, 12:55 PM
renagade is spot on! its fluid. everyone should follow his bleeding steps every 2000mi cuz not only can they lock they can also overheat w old fluid and fail. seen it. not good! brake fluid is cheap
showtime4 is offline
post #7 of 11 (permalink) Old 01-26-2011, 04:31 PM
My 96 Formula SL had this same issue, bled brake and it worked for awhile but repeated quite often. Someone else commented on a small pinhole inside the master cylinder he needed to use a pin to unblock and then bled system again and it worked great....
Rob52 is offline
post #8 of 11 (permalink) Old 01-27-2011, 10:38 PM
yes it is that small pinhole people are mentioning, i had the same problem on my 96 formula z 583, what you need to do is take the master cylinder cover off and soak up all the oil in the top so that its empty, there should be a very small hole right beside the main one that is clogged up, you need to take a small sewing needle or something similar (yes its that small) and clear it out. once you have the hole cleaned out just bleed the brakes (you can find good videos on youtube) and you should be all good to go, this is what i did and its been working great since
ThorndaleRide69 is offline
post #9 of 11 (permalink) Old 01-31-2011, 12:39 AM Thread Starter
Thanks for your help. I bleed the system and my sled worked great over the weekend. Again Thanks!
post #10 of 11 (permalink) Old 01-31-2011, 09:41 PM
Renagade's Avatar
no problem, my sled has been fine since
i did the bleeding. i love triples!!
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e
Renagade is offline
post #11 of 11 (permalink) Old 02-08-2011, 07:09 AM
I've had the exact same symptoms and was have noticed the same exact small clogged hole. I actually ended up taking the master cylinder out of the rubber boot (attached to the break handle). The only thing I didn't know how the seal on the end of the plunger can fit back through the boot. Maybe I shouldn't have taken it apart, but I was really tying to clean everything out.
250Enticed is offline
