The red cap on the RAVE valve cover should be turned all the way in and bottomed in normal use . At high altitude , over 8000 ft or if the engine has been modified , then they may need to adjusted out , up to a maximum of 4 turns.
The only possible maintenance required would be cleaning the carbon of the guillotine or cleaning oil out of the diaphragm.....Jari
