2005 Mach Z 1000 - Engine problems - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 18 (permalink) Old 12-13-2010, 12:05 PM Thread Starter
I was riding my sled yesterday with no issues at all ..
end of day, my sled crapped out...
- I hit the gas full throttle ... got to about 100 km/h
- all of a sudden the sled stalled and came to a complete stop.
- I tried starting it again .. no go ...
- I tried pull starting it .. seems like the motor is seized. I broke the recoil.
Anyways, I was taking the belt off to have it towed back ..
- I guess I free'd up the motor from the crank by doing so .. Motor turns over now, starts but seems like its running on one cylinder ..
Any Ideas on where to start troubleshooting ???
gangasingh1 is offline
post #2 of 18 (permalink) Old 12-13-2010, 12:15 PM
You have burnt a piston.
post #3 of 18 (permalink) Old 12-13-2010, 12:18 PM Thread Starter
Thanks RJ ... i was hoping it was something small .. damnit ..
Anyways, do you know where I can get a manual .. I need to fix this thing ..
Any suggestions on how to change a piston ?
post #4 of 18 (permalink) Old 12-13-2010, 12:46 PM
Jerrys1's Avatar
When you rebuild be sure to check your fuel pressure both low and high your engine is prone to failure of the low pressure fuel pump causing the engine to lean out and melt down.
Ski-Doo -"They said it was impossible to break 3pounds per horsepower. Thats exactly why we did it!"
15 Renegade XRS 800 etec
10 Ski Doo MXZ X 600Etec
Jerrys1 is offline
post #5 of 18 (permalink) Old 12-13-2010, 01:01 PM Thread Starter
would you advise to change both pistons ? or just the one with issues ?
post #6 of 18 (permalink) Old 12-13-2010, 01:52 PM
If you use OEM, just one. If you use after market, both.
post #7 of 18 (permalink) Old 12-14-2010, 06:20 AM
Have you done a compression test on it yet?
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #8 of 18 (permalink) Old 12-14-2010, 09:59 AM Thread Starter
I will be doing so today !
Thanks for the suggestion smallengineguy !!!
post #9 of 18 (permalink) Old 12-14-2010, 01:45 PM
twins rule!
the proper way to fix a skidoo, is to replace it with a polaris or artic cat. sorry dude I feel your pain,thought a joke might help.
farmaloose is offline
post #10 of 18 (permalink) Old 12-14-2010, 01:59 PM Thread Starter
Lol .. thanks Farmaloose .. this is my first skidoo .. I still have my Polaris rmk 800 ...
Anyways, I did a compression test .. 45 lbs on one cylinder ...
So basically i have to replace a piston and the gaskets ... Anything else ??
Why would this fail ??
Oil Pump bad ?
How can I check to see if the oil pump is ok ?
post #11 of 18 (permalink) Old 12-14-2010, 02:00 PM Thread Starter
You guys know of any links of how to replace a piston ??
post #12 of 18 (permalink) Old 12-14-2010, 03:15 PM
Jerrys1's Avatar
Like I said in my first response your engine is very prone to meltdown due to fuel pressure problems you have a low and high pressure fuel pump and it is very common to have a problem with the low pressure pump causing a lean burndown. highly unlikely that you have an issue with the oil pump. I would suggest a little searching over at Dootalk in the machz section you will find lots of good reading on the cause of this failure and many good sugestions to keep it from happening again. just a start would be adding fuel pressure gauges and an exhaust temp gauge with preset warnings so you can see if you start to loose fuel pressure or if you start to go lean and raise exhaust temps.
Your sled should always maintain 58-62 psi of fuel pressure on the high pressure side if your low pressure fuel pump starts to have issues you will see dramatic drops on the high pressure side it will drop 25-30psi
I would also suggest getting a manual and doing a leakdown test before you dissassemble the engine to see if your crank seals are leaking they can also be a cause of a meltdown especially if the cylinder you melted down is the pto side.
Owning a MachZ is like having a high maintenance girlfriend if you knew the true cost of keeping it up going in you would never do it!
Jerrys1 is offline
post #13 of 18 (permalink) Old 12-15-2010, 06:30 AM
I'd take one of those MAch Z's in a minute. Baddest sled Doo ever made IMO.
1999 Ski Doo MXZ600
post #14 of 18 (permalink) Old 12-15-2010, 07:40 AM
Jerrys1's Avatar
No argument there I have been thinking of picking one up as a second sled for when we get on the lake and such but there are some things that need to be done to give them some reliability.
Jerrys1 is offline
post #15 of 18 (permalink) Old 02-07-2011, 01:50 PM Thread Starter
$1600 dollars later, I managed to get her going ! I'm scared its going to happen again.
Also, i bought a Silencer but there is not hole for the EGT, like in the stock muffler. Buddy says just to tie it up somewhere .... Do you think this is correct ?
post #16 of 18 (permalink) Old 02-09-2011, 08:46 AM
twins rule!
did you go to the doo site+check it out like jerry said?
post #17 of 18 (permalink) Old 03-07-2014, 04:41 PM
05 mach z 1000 piston melt down
hi guys I just had my right side piston go down and it wasn't because of fuel pressure because I have always had a pressure gauge and it never dropped n pressure, so now iam really dumfounded why this happened. I worst of it all i just it rebuilt the winter before last I prob has 1000 miles on it. I Did a ton of research to keep this from happing and all the updates but ended up being a waste of time. I guess it is the nature of the beast
fastdana is offline
post #18 of 18 (permalink) Old 03-11-2014, 12:49 PM
NH, ME and VT Rider
My buddy just blew the engine in his Mach Z, I was behind him and all of a sudden there was a ton of smoke. There was antifreeze and oil pissing out. The sled only had 2800 miles on it. We had to tow it 15 miles to the nearest road.
elvis is offline
