Those bolts hold up the front suspension arm. If the front shock on the rear suspension is stiff or locked up it will sheer them bolts off. Another is if the limiter strap is broke or installed improperly the front of the suspension will drop under accelleration and push down, then when you hit some bumps or highpoints at a higher rate of speed they will break due to extreme force applied at the bolts holding the wheel. Make sure when you replace the bolts, use high grade bolts, i used grade 8 and havent had a problem. If it still breaks bolts after your shock change, then measure from the center of the boltholes on each side of the front arm. What happens alot is when you weld, it will shrink on one side from heat and make it shorter. As long as your running the factory wheels and not the oversized 141mm like me, you shouldnt be breaking them at all, that means you could have tweaked the suspension rails or the arms are warped.
96 Formula III 600 Triple
86 Pantera 440, ladies
