rotax 470 problem
i ave 0ne mach 1 in my garage the compresion whas ok on the 2 cyl. (125 each) i ave very good fire on the 2 spark plug the carb was clean the engine start and run good at iddle when i remove the left spark plug wire the engine dont change song but when i remove the right one the engine stall like if i ave cut out the engine. I ave tried to take a ride with the sled and it run to about 100 feet and dont do more like if the engine ave any power. If you can help me it will be very apreciated
