1996 Ski-doo MXZ 583 died and wont start - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 14 (permalink) Old 02-06-2010, 10:47 PM Thread Starter
SkippyMXZ583's Avatar
i have recently purchased a 1996 Ski-doo MXZ 583, when i bought it, it ran perfectly fine, and when winter came, i had a friend of mine, who is a lisenced small engine mechanic, do a pre season on the sled, he fixed all the problems, and had it running like a brand new sled. finally, the snow is here, i have put about 2000 miles on the sled, and had not a single problem with it, other than my wallet hates gas stations haha.. i had it out the other night for a quick ride with some friends.. not even 5 miles from home, the sled died on me, so i did what i was always told, and removed the spark plugs, checked for spark( there was plenty) i pulled it a few times without the plugs in it, and put them back in, primed it once, and it fired right up. after that, it ran perfect again. the next day, i was out on it again, and when i would shut it off, it would take a bit to get it started...once i got it started, i was off, hit the trails, and some local riding spots. on my way home that night, i was about a mile out of town, and it died on me again, so i did the exact same as i did the previous time, exept this time, it wouldnt fire back up...after 3 straight hours of pulling my arse off, i decided to call a friend with a truck, and he took it home for me...i let it sit over night, and went out for trial and error in the morning, i pulled it over when i went out, and it sputtered a bit, then died again, and again, wouldnt fire up. after another 2 hours of pulling it over, and checking for spark and trying all sorts of small tricks ive heard of, it wouldnt run...i finallly got it to run, and it would run perfect while i was giving it throttle, but once i let off the throttle to let it idle, it would die, so i was back to trial and error to get it started again, i finally got it started again, but was doing the same thing. it runs good after i spend hours and hours on end getting it to actually fire up, but wont idle, and takes forever to start it, it will sputter a couple times, and not fire right up, but eventually with alot of pulling, it will start, but still wont idle, and soon as it shuts down, takes forever to start again....spark plugs are brand new, lots of spark, seems to have lots of compression, just doesnt wanna start, and when it does, it wont idle.....does anyone know what could be causing this? im not much of a small engine mechanic, so i am here to get some advice on what may be the problem....thanks for any advice you may have
SkippyMXZ583 is offline
post #2 of 14 (permalink) Old 02-07-2010, 12:55 AM
formzmike's Avatar
sounds like it flooding out....pull the plugs and pull it over if fuel is spraying out thats the problem...it could be a primer issue allowing fuel through or your carbs need to be cleaned again
formzmike is offline
post #3 of 14 (permalink) Old 02-08-2010, 10:24 AM Thread Starter
so, i took the carbs off, and cleaned the Sh*t outta them, they couldnt be any cleaner..still not firing, the odd time when i pull it, it sounds like its about to fire up, then it doesnt, im am very confused, i still cant seem to figure it out, any other siggestions on what might be causing the sled to not fire up? i am getting plenty of fuel to the carbs, but doesnt seem to be flooding out, cuz when i take the plugs out, they are a bit wet, but not flooded, and the plugs are beand new....im kinda new to this, so anything you think may help my out, let me know, thanks
post #4 of 14 (permalink) Old 02-08-2010, 10:55 AM
When it`s about to "sounds like its about to fire up" hold the throttle in all the way and then at the same time try to start.
veiviser is offline
post #5 of 14 (permalink) Old 02-08-2010, 10:57 AM Thread Starter
i have been trying that, which is why it really confusing me, its still not starting
i am really confused with it lol
1996 Ski-Doo MXZ 583
3" handle bar riser
Protaper bars and bar pad
Powermadd handgaurds
rear suspension from a 2000 MXZ
2000 Ski-Doo MXZ 600"Sleeper
1998 670 Engine
4" Rox Pivot Riser
Protaper Bars and Bar Pad
Yellow Powermadd handgaurds
Dynoport can
post #6 of 14 (permalink) Old 02-08-2010, 11:03 AM
take out the spark plugs and fire up the lighter into the holes, the try again
veiviser is offline
post #7 of 14 (permalink) Old 02-08-2010, 11:06 AM Thread Starter
done that already too haha
ive done every trick i can think of to try to get it to fire, but still wont
3" handle bar riser
1998 670 Engine
4" Rox Pivot Riser
Dynoport can
post #8 of 14 (permalink) Old 02-08-2010, 11:15 AM
did u trie getting new plugs because skidoos hate ngk plugs my sled was doing the same thing and my friend told me to trie putting champions in it and they worked allot better and dont get the 4$ champions get the 8 to 10$
1999mxz440f is offline
post #9 of 14 (permalink) Old 02-08-2010, 11:20 AM Thread Starter
i will give that a try, it ran perfectly fine with NGK plugs before tho
3" handle bar riser
1998 670 Engine
4" Rox Pivot Riser
Dynoport can
post #10 of 14 (permalink) Old 02-08-2010, 11:24 AM
mine did to but i kep fouling plugs like my sled would run just out of no were it would start running on 1 cylinder and then none i checked my plug and they had spark i tried champions and it didnt do i for a tong time
post #11 of 14 (permalink) Old 02-08-2010, 11:25 AM Thread Starter
alright, i will give that a try, and see what happens
3" handle bar riser
1998 670 Engine
4" Rox Pivot Riser
Dynoport can
post #12 of 14 (permalink) Old 02-08-2010, 11:25 AM
how do u post disscution im new ant this site but i know alot about motors
am only 14 and u give me a motor i can rip it down and fix it and it will run again
post #13 of 14 (permalink) Old 02-08-2010, 11:55 AM
so can u help me because my sled blows up and it does not show why soo i wana post an add to help me disc. the prob.
post #14 of 14 (permalink) Old 02-10-2010, 06:14 AM
Click "new thread" in the section you want to post in.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
