speedo question
the speedo should move whenever the track turns rihgt? if so i think i didnt get the speedo lined back up right after insdtalling new track. is there a way to get it in there right with out removing suspension and track shaft again?
one last question. i started her up today to adjust track tension. it sure smoked bad. i double checked the oil injector pump setting and it was right. could it possibly be the oil that hte previous owner used? what can i do to find out whats causing it? the smoke is a whitish grey color.
i wanna get this set cuz its SNOWING OUT RIHGT NOW. supposed to get 6-9 inches tonight
