Old 12-18-2004, 08:15 PM   #1 (permalink)
Formula_SL_ryda
95 Ski-Doo Formula SL
Formula_SL_ryda's Avatar
idler wheels
the rubber on two of my idler wheels has came off i was wondering if the idler wheels are universal between yamaha, skidoo, polaris ECT.?
Formula_SL_ryda is offline   Reply With Quote
Old 12-19-2004, 10:27 AM   #2 (permalink)
01MXZ800
01MXZ800's Avatar
most sleds use the same bearings, however the diameter of the wheels vary from one sled to another if you are refering to a ski-doo the idlers are 5 3/8" in diameter for the skid wheels and 6 3/8
for the rears but check your rears, ski-doo used a larger rear wheel on their older sleds. hope this helps!
01 MXZ 800
Old Erie Riders Snowmobile Club
Old 12-20-2004, 02:29 AM   #3 (permalink)
dbenney
actually those numbers are a tad off. ski doo oem wheels are measured in mm. given you have an older sled chances are that your back wheels are 180mm and the smaller ones on the bottom are 135mm. the top return wheels should be 100mm. just call the dealer give them your sled and year & they can look it up. you can go with larger wheels but i wouldnt go too much bigger. if you want to get other design wheels(which are measured in inches) here is the formula to figure out the size.
inches * 25.4 = mm
mm / 25.4 = inches
eg
stock wheels for my 98 FZ 670 are 180mm & 135mm
180/25.4= 7.087
135/25.4= 5.314
so if you decide to go with another wheel id suggest a 7.125 for the back & 5.375 for the smaller ones.
also the bearings are a 6205 which is a 25mm ID bearing.
I know i just replaced all my wheels & bearings.
like i said though call the dealer & find out what size is on your sled.
dbenney is offline   Reply With Quote
Old 12-20-2004, 06:26 PM   #4 (permalink)
01MXZ800
01MXZ800's Avatar
they may be listed at a DOO dealer in mm but most catalogs i use
have converted mm to inches and the sizes that i refered to were from dennis kirk and two other catalogs i looked at used the same dimentions.
01 MXZ 800
Old 12-20-2004, 08:56 PM   #5 (permalink)
dbenney
you are right most aftermarket wheels are listed in inches, but if you notice you cant get the exact size. the closest i could find to 180mm was 7.125 which is a tad larger than the 7.087(stock). also the closest i could get the the 135mm (5.314) was 5.375. asy you can see you will never find the exact size unless you get it from a Doo dealer, but you can get close enough to where it doesn't matter.
Old 12-22-2004, 12:08 AM   #6 (permalink)
95_SL_Ryda
thanks guys for all your help i went out and got a couple that fit perfectly!
95_SL_Ryda is offline   Reply With Quote
