MXZ 470 Problem - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 5 (permalink) Old 01-10-2010, 08:07 PM Thread Starter
MXZ 470 Problem
Hello I have a problem maybe someone can help me with
1994 mxz 470
rebuilt motor 200 miles ago
ran great and then it just lacked power and would bog out
I put new plugs in and gaped them . The muffler was a bit loose so i tighted that up
it has 150 PSI in one piston and 143 in the other
I think the carbs need to be tuned I did pull them apart and cleaned them I did not touch the air screw and idle untill i put them back on then I tuned them clockways 1/2 turn and it runs better .
It runs great and start up then like 1/2 mile down the road it will spit and spudder and you have to play with the gas to get it to go . I was thinking that the auto oiler was bad so i mixed it in the tank .. and now i hooked the auto oiler back up . I do not want to blow the motor . The plugs are not oily looking . I would call them and tanish color like a paper bag burning . Also i checked all the seals with eather to see if I have a air leak .. Can somone help
chadmilliser is offline
post #2 of 5 (permalink) Old 01-10-2010, 09:13 PM
Your fuel pump may need a rebuild.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 5 (permalink) Old 01-10-2010, 09:14 PM
Dbl R's Avatar
Check Cluthes/Belt, sticky brake ... Sounds to be running good with those plug colors. check throttle cable adjustment also!
Dbl R is offline
post #4 of 5 (permalink) Old 01-10-2010, 09:40 PM Thread Starter
thanks
I was thinking fuel pump !!! I have a few around tomarrow i will buy pass the old one and try another one .
post #5 of 5 (permalink) Old 01-13-2010, 12:27 AM Thread Starter
crank bearing
hello there I found out what was messing it up . the crank bearing on the pto side . If you look down by the cluch you can see a spot as thin as a penny that is shinny metal . like the cluch slid! and if you spray ether on it for a bit it will slowly rev !!! so i got the motor all tore down and a good crank shaft and seals on there way . Im taking it to a shop to pull my cluch and stator and then have them retime it . they told me 20.00 $$$$ to do all this ! is timing of this think hard I know it will be hard to get the new crankshaft in the same spot as the old . is there any good way to time a rotax 470 !! MY old bottom end had 200 miles on it and it is clean as can be !!! and i have to replace it .
