need help removing 1994 skidoo mxz seat - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-16-2009, 11:55 PM   #1 (permalink)
let it snow
need to replace the seat cover on my 1994 ski doo MXZ sled, can't figure out for the life of my how to get the seat off so I can have the seat recovered, I know this is a little weak, but don't want to wreak something and know someone out there has had to do this before thanks for any assistance, Ill return the favor for someone else thanks
bosterha is offline   Reply With Quote
Old 11-17-2009, 12:43 AM   #2 (permalink)
Mountain Man
lowbudget's Avatar
there are 2 10mm nuts under seat in tunnel, actually the nuts are smaller but you need a 10 mm wrench LOL. It is best to soak with penatrating oil before trying to remove. I 'll try and find the thread on here on how to do it. http://www.snowmobileforum.com/ski-d...-800-seat.html Here you go. If you snap the T bolts off you can replace them when you have cover off. Here is a link on DIY seat cover Upholstery -- Recover your Snowmobile Seat I found my post when I recovered my Summit seat which is the same as yours but the photos have been deleted off of photobkt. It wasn't that hard to do. I reused the glove box flap on the 1st one I did and recovered the 2nd one I did.
As Red Green says "Keep your stick on the ice." Thanks Mike
lowbudget is offline   Reply With Quote
Old 11-17-2009, 06:30 PM   #3 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
Sometimes the bolts go all of the way through the tunnel and into the compartment of the seat so if you do break a bolt, no biggie. Take a look in there and under your rear bumper, about 12 inches in.
Snow: The other white drug!
Old 11-18-2009, 09:18 AM   #4 (permalink)
let it snow
thanks, found the bolts!
they are very difficult to get at as the deck they run through is ribed and my short 10mm socket was too wide to get around the ribbing, purchased some longer metric sockets today that are a little narrower at the socket end, will try again tonight. again thanks
Old 11-18-2009, 09:19 AM   #5 (permalink)
let it snow
Will try again tonight to get them off
