Old 11-07-2009, 12:09 PM   #1 (permalink)
Gunther47
just mEEEEE
How could i install a primer?
I have a 2000 Ski-Doo MXZ 600 and a cold start takes a lot of pulls just to get gas to the cylinders.how could i install a primer so that less pulls are necessary?
Gunther47 is offline   Reply With Quote
Old 11-07-2009, 12:11 PM   #2 (permalink)
polaris rider
PR (polaris rider)
polaris rider's Avatar
That sled has a choke corect? If its hard to start, usualy indicates a problem, like bad compression.. no need for a primer, thats just a cover up for a deeper problem,, check your compression
1999 AC zl 500, 3k miles2003 polaris classic 340 1200 miles-2003 polaris indy xc 500 1500 miles-2000 polaris xc 700 6500 miles-2003 arctic cat zl 600 1500 miles
"Dont let fear and common sense stand in your way!"
polaris rider is offline   Reply With Quote
Old 11-07-2009, 07:09 PM   #3 (permalink)
Definitely check compression first. Then make sure your choke plungers are working/adjusted correctly.
Old 11-07-2009, 10:25 PM   #4 (permalink)
Gunther47
just mEEEEE
good compression its just a metter of pumping fuel that distance. it runs great once its started!
Old 11-07-2009, 10:38 PM   #5 (permalink)
polaris rider
PR (polaris rider)
Clean carbs then, and make sure ur choke is working
Old 11-08-2009, 07:14 AM   #6 (permalink)
Gunther47
just mEEEEE
I just cleaned the carbs and changed spark plugs. the problem lies in geting fuel 4 feet from the gas tank to the cylinder. I asked "How could i install a primer?" not "Do i need a primer?"
Old 11-08-2009, 07:19 AM   #7 (permalink)
kikkinurazz3
Install a pump bulb in the gas line going to the carbs if you are so inclined. The fuel should not be running back to tank as it sits though. You do have a problem with chokes, fuel pump pinhole, shut off valve etc. I would find the cause nd fix the cause. Good luck.
2003 Arctic Cat F-7 700
1999 Arctic Cat Thundercat 1000
!996 A Cat Panther 440
!995 A Cat Panther 340
!997 Polaris Indy 500 Sport
1995 Polaris Indy 440
1983 Indy 500 Trail- Parts sled now
!996 Yamaha V-max 600-Sold
kikkinurazz3 is offline   Reply With Quote
Old 11-08-2009, 07:21 AM   #8 (permalink)
Gunther47
just mEEEEE
gas evaporates, dude. not so much a problem now with the cold weather. in the summer it was bad. i'm probly re-doing my gas lines after this season
Old 11-08-2009, 07:52 AM   #9 (permalink)
Ultrafrozen
Ultrafrozen's Avatar
Originally Posted by kikkinurazz3 View Post
Install a pump bulb in the gas line going to the carbs if you are so inclined...Good luck.
^^^Easiest and cheapest way to add a primer.
You can also drill and tap the crankcase or carb (after the slide) for a direct injection of gas. Make sure to install all the appropriate check valves.
If this is a regular problem after having run the sled a short time before then follow your fellow sledder's advice and look into why this is happening as this is not normal. I can start my sleds after a few months of sitting with about two or three pulls. My Polaris sleds don't use a primer but have an enrichment circuit. My Ski-Doo does not have a choke or enrichment circuit but has a primer so I usually give it two shots before starting.
I would guess that your pilot jet is plugged with varnish from the gas evaporating. This is the smallest jet and also the one used when at idle speeds.
Side note: I read on this forum that a lot of areas in the states are using ethanol fuels. Ethanol is great at disolving the varnish and crud in the fuel system. Unfortunately, this newly released crud plugs fuel passages with jets being the bottleneck. Even if you don't use ethanol blend, new gas also dissolves old crud. This happens at the beginning of the season usually after the first ride for a lot of sledders.
1994 Skidoo Grand Touring 580
1997 Polaris Indy 500 classic
Old 11-08-2009, 09:19 AM   #10 (permalink)
polaris rider
PR (polaris rider)
Ok, were trying to offer our advice and find the real problem, I have 5 sleds and all have a choke, and i dont need to have a primer to start them... nor do alot of other members on here.. theres obviously a reason or problem why the fuel wont make it to the cylinder.. but hey, if u just want to use a cover up and add a primer go ahead..
