Old 11-03-2009, 09:05 PM   #1 (permalink)
SColum
SColum's Avatar
Question Cleaning Points. 77 340e
Hey I was just wondering how am I to go about cleaning the points on my 1977 ski-doo everest. Also were are the points exactly located?
SColum is offline   Reply With Quote
Old 11-04-2009, 07:42 AM   #2 (permalink)
Should be cdi, no points.
Old 11-04-2009, 02:44 PM   #3 (permalink)
SColum
SColum's Avatar
Really how could I makes sure?
Old 11-04-2009, 06:00 PM   #4 (permalink)
Coil has two wires coming out of it, rather than two separate coils.
Old 11-05-2009, 07:40 PM   #5 (permalink)
SColum
SColum's Avatar
Ok so I have two seperate coils, so therefore it is??
Old 11-05-2009, 10:09 PM   #6 (permalink)
SColum
SColum's Avatar
I have been reading around and I am now almost positive I have points because the wires from the coil go into the engine not through a box. I have also read some things about points and it sounds really confusing and I do not want to mess up the timing, so is there a way I can just clean them that wont have me messing things up.
Old 11-06-2009, 07:42 AM   #7 (permalink)
You can clean them easily.
You will have to take off the recoil and starter cup and fan pulley.
Then you can see the points through the ports on the flywheel.
You can use either a points file or a fine grit Emory board. Use a small screwdriver to lift the breaker open and insert the file. Make only two strokes in and out to clean the contact. Any more and you risk taking too much off and have to reset the gap.
Old 11-06-2009, 03:50 PM   #8 (permalink)
SColum
SColum's Avatar
ok cool
