hopefully minor problems on 89 mach1
hi im new two this forum and i have a couple issues with an older sled i just bought. i havent had a whole lot of experience with sleds so any help would be awsome! the first thing i noticed was track seems a little out of allignment. it seems like its tracking a more to the left and its almost or already to the point were the guides on the track are starting to rub on the slide rail. i noticed you can adjust it on the back wheels to get it back in the center but if i do that will i have to adjust anything up front? on to my 2nd question..the drive shaft on my sled seems like it could be bent when i give it some gas and it starts to rotate seems like it wobbles a little not real bad though. is this a huge deal or no? last question! the motor bogs when you first give it gas and then if you keep on it , it will finally pick up. ive cleaned the carbs drained the tank and replaced the fuel lines. also it seems like the carb on the right closest to the oil tank has a little more vaccum to it if you hold your hand over it? well thats the issues i got any help would be great! thanx
