Mechanical Reverse not engaging
OK
So I installed a mechanical reverse and it will not engage into reverse. I here a tick tick sound when I move the clutches, like the chain is slipping over the middle sprocket assembly, 19 tooth?
Everything seems right, the only part I did not have was the chain slider, ( the one that bolts onto the side of the chain case). Is this a crucial part to have? Does it somehow hold the chain down onto the 19 tooth gear? I am stumped and this is the only solution I can think of.
Thanks in advance.
