Old 10-28-2009, 07:29 PM   #1 (permalink)
TheMessinger
1990 Formula Connecting Rods
Would anyone have advice on how 'loose' connecting rods should be on the crank? I've removed the pistons and top-end of the engine to replace a piston and rings. However, I noticed that when pulling on the connecting rods there is some play vertically when I pull or push on the rods. Is this normal?
TheMessinger is offline   Reply With Quote
Old 10-29-2009, 12:08 PM   #2 (permalink)
They should move side to side a little, but not up and down....
Old 10-29-2009, 05:14 PM   #3 (permalink)
TheMessinger
Advice well taken. I'm guessing there is 1mm worth of movement up and down, which tells me the needle bearings and/or the crank are wearing poorly...probably the source of why the piston rings failed and dimpled the cylinder head....
Time to weigh a lower end rebuild vs alternative engine...
Thanks. Paul
Old 10-30-2009, 07:17 AM   #4 (permalink)
No problem. Probably had a lot of miles on it, huh? A used motor should not be too hard to find. They made millions of them.
Old 11-01-2009, 12:07 PM   #5 (permalink)
TheMessinger
Speedo only says 6500kms and the sled is in amazing shape (ie steering booties are still intact). Looks garage kept its whole life. Any thoughts on what a used motor should cost? Thanks
Old 11-01-2009, 09:28 PM   #6 (permalink)
Around $500-$600 somewhere.
