Old 10-26-2009, 02:55 AM   #1 (permalink)
tlito
MiniZ Help - idle problem.
I just got my son a 1998 Mini Z ... starts up no problem, runs but does not idle ..
I did the following:
1) Changed the plug - it was fouled.
2) Used carb cleaner (spray) on the carb.
3) Adjusted the throttle cable - to give it a bit more fuel
well .. here is the question. It seems to 'idle' after the adjustment but ... with the track off the ground .. it turns. is that the correct behavior?
I suspect i am going to hear to take off the carb and clean it - i have the shop manual and looked the procedure .. not sure i want to undertake that myself. So before i take the sled to someone to tune it, wondered if there was something else i should do?
tlito is offline   Reply With Quote
Old 10-26-2009, 05:57 AM   #2 (permalink)
snowtrax00
Well if you adjusted the throttle then maybe the clutch is engaging
snowtrax00 is offline   Reply With Quote
Old 10-26-2009, 07:24 AM   #3 (permalink)
The carb needs to be cleaned. The track should not turn. Remove the carb and clean it. What I do is actually remove the carb bolt studs from the engine. Makes it MUCH easier to remove the carb.
Old 10-26-2009, 11:19 AM   #4 (permalink)
tlito
thanks but help needed
do you have instructions or pictures to show me how to do it?
is it just remove and dunk in solution?
Old 10-26-2009, 12:17 PM   #5 (permalink)
First remove rubber and plastic parts.
Old 10-26-2009, 09:11 PM   #6 (permalink)
Remove the carb from the machine, then remove the bowl and float/needle. Then unscrew the pilot jet and use carb cleaner AND compressed air to clean it all really good. You NEED the air.
