Old 10-20-2009, 08:45 PM   #1 (permalink)
Goblue2979
Question HELP!! 1999 MXZ 600 Oil Pump Question??
I need HELP, please!!! I have a 1999 MXZ 600 with a bad oil pump. I have pulled off the oil pump and it doesn't match the new one I received. I think the one I received is from an '03 MXZ 500. Does anyone know if these two pumps are compatible performance wise? At this point in time, I don't even know if the "new" one will line up with the cast. I have tried to research these two pumps online and I have not come up with much. THANKS!!
Goblue2979 is offline   Reply With Quote
Old 10-20-2009, 09:05 PM   #2 (permalink)
stangcruzin
stangcruzin's Avatar
Not the same pump.99 mx z 600 #420 888 260...........03 mx z 500 420 888 780
they are different for a reason
Check.... Ronnie's Mail Order for atv parts, atv tires, snowmobile, watercraft and motorcycle featuring an OEM microfiche parts finder.
stangcruzin is offline   Reply With Quote
Old 10-20-2009, 09:09 PM   #3 (permalink)
Goblue2979
I had that feeling. I know that the original pump on the sled does not flow at idle...maybe that is the difference between the two. Thanks for the response.
Old 10-20-2009, 09:10 PM   #4 (permalink)
stangcruzin
They don't flow at idle,that's the way the work from the factory.
