Bustamove,
If the movable sheave is not moving smoothly when there's no spring in the primary, you may have a bad primary bushing. Some are repairable, but it takes some special tools to get to it... if you have one clutch, pay to have it overhauled. I sent a clutch to SLP for balancing and repair, it came back looking new and ran awesome!
What temperature are you running the sled at? What is the air screw set to? Try one turn out to see if you can get rid of the low end bog... if not, try turning the air screws in 1/8 of a turn until the bog is eliminated. If you bottom the air screw, go back to cleaning, and pay particular attention to the fuel and air passageways leading to the pilot jet. You may have to poke a small wire through all the holes to get the varnish dislodged so the pilot jet works properly. (I use one strand of telephone cable with the insulation still on.. seems to work well for me).
Fuccillo,
Sticky weights can definitely cause a higher engagement RPM and a very harsh engagement. Because the weights are sticking, the engine has to turn the primary faster than normal before the centrifugal force of the weights overcomes the sticky weight. A faster engagement will result. You could also have a sticky roller or a sticky main bushing, which can cause the same problem.
