Old 06-22-2009, 06:51 PM   #1 (permalink)
Lisa's Ski Dpp
Lisa's Ski Dpp's Avatar
1997 Ski Doo SLE Touring Fan Cooled
What should be aprox compression on this sled be. I am looking to
purchase it and I checked out the compression which read 90 psi on
each cylinder, is this compression all right or to low.
With that kind of compression do you think it will need pistons and rings soon?
It has around 1200 miles on it and looks in excellent condition.
Lisa's Ski Dpp is offline   Reply With Quote
Old 06-22-2009, 07:43 PM   #2 (permalink)
JheLrey
TRH- Troll Raising Hell
JheLrey's Avatar
Low... but did you test it with only that one spark plug removed, safety on, and the throttle wide open?
Old 06-22-2009, 08:16 PM   #3 (permalink)
Lisa's Ski Dpp
yes only one plug out and did not hold wide open throttle. i guess i did it wrong? what is the right way to test
Old 06-22-2009, 08:36 PM   #4 (permalink)
Remove all the plugs, leave ignition off and hold throttle wide open. Pull it over at least three times as fast as possible.
Old 06-23-2009, 07:12 PM   #5 (permalink)
Lisa's Ski Dpp
doing this will make the compression go up or down
Old 06-23-2009, 07:55 PM   #6 (permalink)
SkiDoo86
Well it should go up. because there will be no resistance on the pistons. So ull be able to get max compression.
SkiDoo86 is offline   Reply With Quote
Old 06-23-2009, 07:56 PM   #7 (permalink)
Compression should read around 120psi
Old 06-23-2009, 08:32 PM   #8 (permalink)
Lisa's Ski Dpp
what do you think the compression increase would be if it's at 90 psi now doing it the wrong way and then doing the compression check the correct way
Old 06-23-2009, 09:11 PM   #9 (permalink)
See the post just above.
Old 06-23-2009, 09:26 PM   #10 (permalink)
Lisa's Ski Dpp
so you are saying it will jump from 90 to 120
Old 06-24-2009, 08:23 AM   #11 (permalink)
Quite likely, yes.
If it doesn't, then there is a serious problem.
Old 06-24-2009, 11:11 AM   #12 (permalink)
Lisa's Ski Dpp
thank's to everyone for the info
