Help! installing C7 suspension - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 02-05-2009, 06:08 PM Thread Starter
I bent up the rear suspension from my 1993 mach 1, and needed to buy another suspension. I could not find any other mach 1's so i bought a very similar one from a 1996 formula III 600.
I attempted to install it myself, and I got the front in, bolted up the "shock bar" and placed the shock on the swayarm.
My problem is when I go to mount the swayarm to the tunnel bracket, the suspension lifts up and touches the rear idler wheels. There is also lots of surplus track.
the front of the suspension seems not to even come down, and be fairly tight to the tunnel. The tensioner strap is not tight in any way, so thats not preventing it.
Please give some insight as to what I am doing wrong.
jbezan is offline
post #2 of 10 (permalink) Old 02-05-2009, 08:51 PM
Ultrafrozen's Avatar
Between 1993 and 1996 there was a chassis change; were you told it would be a drop in fit?
Ultrafrozen is offline
post #3 of 10 (permalink) Old 02-05-2009, 09:36 PM Thread Starter
Yeah i was told it would be a drop in fit. Anybody know what i will have to do to make this fit?
jbezan is offline
post #4 of 10 (permalink) Old 02-05-2009, 09:57 PM Thread Starter
Here is the same suspension as i bought. Mine is red and purple though
jbezan is offline
post #5 of 10 (permalink) Old 02-06-2009, 06:30 AM
If they are side by side, is everything the same?
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #6 of 10 (permalink) Old 02-06-2009, 07:50 AM Thread Starter
I will check when i pull it back out. I know they arent exactly the same. I am missing parts off of my old one, but i dont ever remember a limiter strap
Can someone get me a couple of closeup pictures of what a c7 suspension should look like installed?
jbezan is offline
post #7 of 10 (permalink) Old 02-06-2009, 08:54 AM
You are right, the PRS/C7 had a limiter bolt/nut arrangement.
See free art work.
Your best bet is to make sure the track lengths are the same, then measure the bolt holes from the drive shaft (R1 and R2) and down from the top of tunnel (H1 and H2). If you don't have the donor sled, find a similar model. Compare to your sled. R1 and R2 must be very close while H1 and H2 can vary somewhat.
If they are different, move the existing support brackets or install new ones.
post #8 of 10 (permalink) Old 02-06-2009, 09:47 AM Thread Starter
thank you for measuring diagram. I just gotta find a sled to measure on now
does someone have pic of what 93 mach 1 suspension installed should look like?
closeup pics please
jbezan is offline
post #9 of 10 (permalink) Old 02-06-2009, 12:34 PM Thread Starter
ok i did the measurements and it is not compatible. Would have to move front mounting bracket, and its over my head to do that stuff. (at least i can admit that lol)
I am going to use the bearings and wheels off the new skid and begin to rebuild mine (bearings on new skid have 300 miles)
What i do need now is a list of PRS sleds that use the limiter bolt/nut setup. any help would be appreciated
jbezan is offline
post #10 of 10 (permalink) Old 02-07-2009, 07:05 AM
1992 Mach 1 uses it. OnlineMicrofiche Index has a picture.
1999 Ski Doo MXZ600
