Hey,
I just had my sled out for a drive today and it died on me. The thing was working fine, had it out yesterday for about 4 hours with no problems
Anyways, I was going along and the sled started bogging down on me so I brought the sled to a stop and it started back firing like crazy.. I replaced the spark plugs, started it up and it was going fine again. I then took the sled back out for a bit and it started bogging down on me again, but this time when I let go of the throttle the engine just stopped. Now when trying to start (pull over) the sled, its making this weird clicking/ticking noise
Its nothing to do with the pistons/rings because I did a compression test and both sides are running 125/130 and there is plenty of spark coming from the plugs/wires.. I will mention that it still makes the noise when pulling it over with no plugs in. I can't think of anything, maybe a bearing in the crank/cam? ..someone also mentioned that it could be the rotary valve? haha I'm new to this so any help would be greatly appreciated
Any Ideas, let me know
Thanks!
Logan
Thanks!
Logan
