Old 10-08-2008, 11:12 AM   #1 (permalink)
Z780_owner
Exclamation Clutch setting...
It says in my manual that the max Hp for my 94 MachZ clutch setting should be at 7800rpm'.
She tops out around 9000rpm'......(she does 200kph at that range) How do i set my clutch for it too max out at the 7800rpm mark!?
And will it go faster?
Everything is stock except for a aftermarket MBRP Muffler!!!
Z780_owner is offline   Reply With Quote
Old 10-08-2008, 12:12 PM   #2 (permalink)
skidoorider
skidoorider's Avatar
the factory adjustment only changes the max rpm about 500rpm. if its going all the way up to 9000rpm, your belt might be bad or the clutch springs are worn out.
08 ski-doo mxz adrenaline 800r
04 ski-doo mxzx 800ho
97 polaris xc 600 triple
87 ski-doo safari 377
skidoorider is offline   Reply With Quote
Old 10-20-2008, 04:25 PM   #3 (permalink)
Z780_owner
will it be better to rebuild my clutch or is it better too buy a aftermarket clutch? say a Comet Clucth perhaps?
Old 10-20-2008, 05:03 PM   #4 (permalink)
Start by making sure that the belt is not too thin (worn).
Then check that it is riding up at the top of the secondary (1/8" of the belt out of the top)
If both of these are right, then check where the spring of the secondary is set (1,2,3,4,5) hole on the outer plate.
As the spring is moved forward or back from the center (#3), the peak engine rpms will go up or down by 2-300 rpm.
At what rpm is the primary (engine) clutch engaging?
Should be around 3400/3800 rpm stock.
