Old 05-18-2008, 11:05 PM   #1 (permalink)
ahelsell
Question rebuilding a 700 triple what am i getting into
my 1998 grand touring 700se has a bad crank bearing. I have done a couple top ends on rotax engines, but never bottom end. before I get too deep into it, am I getting into a box of suprizes and bigger headaches? Or is it pretty straigt forward? I plan on getting a remanned crank from ski doo, and I have a ski doo tear down manual...any opinions on re-using pistons? Any tips or tricks are always appreciated...
ahelsell is offline   Reply With Quote
Old 05-19-2008, 07:18 AM   #2 (permalink)
If you're getting a new crank, it won't be that bad. Get some crankcase sealer, and an engine gasket set. Buy new rings for the pistons while you're at it.
Old 05-19-2008, 09:08 AM   #3 (permalink)
ahelsell
that's what I wanted to hear...I don't need to worry about ignition timing or anything because it is indexed off the flywheel, right??
Old 05-19-2008, 06:00 PM   #4 (permalink)
Mark you stator to the crank case mounts so that it goes back in at the exact same spot and you should have no problems.
Old 05-20-2008, 09:30 AM   #5 (permalink)
ahelsell
that is a good idea... I was actually just trying to get the magneto off, but was unsucessful. I got the large 30mm nut off, but can't get the mag assy. to budge. It looks like there is a retaining ring on the I.D. but I can't get it out or even to move, is there a little trick to it or can I put a gear puller or something on it??
Old 05-20-2008, 08:43 PM   #6 (permalink)
Are you talking the flywheel? You need a harmonic balancer puller to get it off.
Old 05-21-2008, 08:45 AM   #7 (permalink)
ahelsell
the repair manual calls it a magneto. it is in the bell housing right under the pull start rewinder.
Old 05-21-2008, 12:55 PM   #8 (permalink)
ahelsell
nevermind, took to my local dealer and they pulled them both off for me for free too.(it was flywheel)
