Old 03-10-2004, 09:04 PM   #1 (permalink)
Zero17
Summer Prep??
It is getting closer to the end of the season and i need to know what to do with my sled for winter its been sitting for a year or so then we put about 200 ish miles on it this winter without doing anything to it. What should we do to keep her running? Anyother cheap things we can do to it to keep it in good contition and maybe improve the preformance?
Snowmobile:
Skidoo 01 MXZ 440
Quads:
Honda 02 400ex
Honda 01 Forman
Zero17 is offline   Reply With Quote
Old 03-11-2004, 12:16 AM   #2 (permalink)
Taz Man
summer prep
First thing I would do is drain all the fuel you can. Fill your oil tank to top. remove spark plugs and spray some Tri- Flow in,pull starter a few times and replace plugs. Maybe a good time to clean and wax machine. make shure to store in nice dry place. Take weight off suspension. It is a good time to clean carburators and rebuild shocks easy to do and does not cost much. Inspect wires, track, and check for loose or missing bolts. When you are ready to ride next fall change chaincase oil. The summer is a good time to think about mods. or improvments you want to try. Good Luck...
Taz Man is offline   Reply With Quote
Old 03-11-2004, 06:26 AM   #3 (permalink)
Also, grease any suspension and steering fittings. These are often forgotten. Everyone's opinion is different on fuel, but I fill mine to the gills every spring and add Sta-Bil or some other fuel stabilizer to the tank, then run it to get it into the carbs. I've never had a bad fuel problem. Plus around July or so, Ill run it for a few minutes anyway, so it'll rotate the fuel through. Plus I need to get a hit of 2 stroke smell in the summer to keep me in line
