» Site Navigation
» Power Sports Links
Old 03-18-2008, 10:42 AM   #1 (permalink)
94 formula z
hi everyone, recently i traded a good runner srv for a 94 formula 583 blown motor, what i need is help, i have the ski-doo manual. but it is missing wiring diagrams. as well i would like a picture of a formula with the shroud open so i can put it back together. i know i am missing alot of parts and the salvage yard is my best friend. i have the motor apart and the crank at a machine shop, it is costing me $670 for a rebuild crank, all seals and gaskets, '20 over pistons with rings and new rods and bearings< i think i am getting a great deal>, any one know if i can put a starter motor on it?, does anyone have a wiring diagram? thanks in advance for your replies
danno583 is offline   Reply With Quote
Old 03-18-2008, 11:54 AM   #2 (permalink)
I have a diagram, what do you need to know?
Old 03-18-2008, 12:50 PM   #3 (permalink)
well i got this machine with the 583 out of it and a fan cooled 500 in it, the guy who i got it from had the harness out of it, and the gauges all have been snipped, i need to do some rewiring but i didn't take it apart to know how to put it bake together. kinda in the dark, been looking all over the internet and cant find one. a schematic would be really helpful. i guess i should really buy a shop manual.
Old 03-18-2008, 01:03 PM   #4 (permalink)
also, when i go to rebuild the motor, i will need to get the rotary valve timed, there are two scribe marks, but i will need a dial indicator, is this to make sure i have top dead center?
Old 03-18-2008, 11:53 PM   #5 (permalink)
another question, i never got the air box with this mess, can i use 2 air filters on the carbs? k&n perhaps. is there any sensors in the air box, or is it just to clean the air?, will have adjusting problems, back pressure?
1994 583 rotax
1993 yamaha big bear 350 4x4
1986 srv 540
1988 xlv 540
1979 invader 440
Old 03-19-2008, 06:22 AM   #6 (permalink)
Find an airbox on eBay if you can, that way there will be no problems with carb icing, etc. Get a Clymer's manual for it too. That's the manual I have, it has wiring diagrams in the back. There is a method for timing the rotary valve, I can post it if you want, but that Clymer manual is your bible for that sled.
Old 03-29-2008, 01:16 PM   #7 (permalink)
well this is what i am into, just got all my parts back from the machine shop, costs a little more than i was quoted, well now the snow is almost gone, cant wait for next year. anyone with helpful tips would be helpful. thanks snowmobile forum
94 formula z-getattachmentca8od3rw.jpg  94 formula z-getattachmentca9z83k0.jpg  94 formula z-getattachmentcaabik7s.jpg  94 formula z-getattachmentcanvasw5.jpg  94 formula z-getattachmentcaydncb4.jpg
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-02-2008, 04:45 PM   #8 (permalink)
well, i have the engine back together, timed and primed. the problem i am having now is the recoil wont recoil with the flywheel on it, i took it off and it works fine, is this ok?
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-02-2008, 05:07 PM   #9 (permalink)
Something is binding. Is the spring that wraps around the hub bent?
Old 04-02-2008, 05:12 PM   #10 (permalink)
the recoil is rubbing on the lips of the hub i will post a pic in a few minutes, thankh seg
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-02-2008, 08:41 PM   #11 (permalink)
i was looking at it and the starter pully is rubbing up against the pawl on the recoil. the only way for it not to rub is a spacer between block and the recoil. i dont have a spacer do you think i can use washers. i guess the flywheel is important. thanks again for your help. i am also using the ski doo shop manual 1994.
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-12-2008, 02:13 AM   #12 (permalink)
i have gotten all the wiring figured out and the motor installed. wondering why there is two fuel shut off valves? and there is two pulse lines off the motor? and aswell i have a seal left over, but there wasn't any room on crank. thanks for the reply s. has anyone used spx pistons?94 formula z-102_2175.jpg
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-12-2008, 02:24 AM   #13 (permalink)
my friend gave me and my daughter that 2up seat, nice guy. thanks
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-12-2008, 06:52 AM   #14 (permalink)
All the sleds of those years had 2 fuel pumps, 2 shutoffs, etc.
Old 04-12-2008, 02:03 PM   #15 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
When you get done, you will have to really wash the motor and engine bay down
Old 04-12-2008, 03:48 PM   #16 (permalink)
Hiberna Somnium
Jim Jessup's Avatar
SPX pistons are fine.
The fleet...
1989 Ski-Doo Formula Mach 1
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
1999 Ski-Doo Formula S
Jim Jessup is offline   Reply With Quote
Old 04-12-2008, 08:31 PM   #17 (permalink)
everytime i go to the hardware store i forget to get a can of engine degreaser
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-14-2008, 09:51 PM   #18 (permalink)
well i got it started today, recoil issue was the start pully, it was the wrong part. the new issue is does anyone know about mikuni carb jetting. i have 440 in both, i live in southern ontario. i was told that they would be too rich. thanks for all your replys
1994 583 rotax
1986 srv 540
1988 xlv 540
1979 invader 440
Old 04-15-2008, 06:06 AM   #19 (permalink)
OnlineMicrofiche Index Look up your year, model, etc. Then click on carbs. That will tell you what the jetting is for the mains/pilots.
