Old 03-11-2008, 08:05 PM   #1 (permalink)
iceman400
iceman400's Avatar
how to pull a secondary?
my dads buddy is gonig to give me two clutches and install them for me on my sled... he asked for me to have all the damaged parts off the sled so work will go faster.. how do i pull a secondary clutch off of a 93 formula plus?.. there is one large center bolt( i removed) and two inset bolts on both sids of the center bolt.. i dont have a socket that will fit them..do you have to remove them to pull the clutch?
thanks
Connor,
1992 Formula PlusX 617
1993 Formula Plus 580
YEA GOTTA LOVE THE PRS!
1996 Jeep grand cherokee Limited
1966 Dodge Charger-BAD ASS
iceman400 is offline   Reply With Quote
Old 03-11-2008, 08:37 PM   #2 (permalink)
Kidder4
when you remove the center bolt the secondary clutch should just slide off, just watch in behind,there could be a shim or 2,if it doesn't slide spray a little wd-40 into the bolt hole and the same at the back on the jackshaft where it slides on,might just need a little help
Kidder4 is offline   Reply With Quote
Old 03-11-2008, 09:12 PM   #3 (permalink)
iceman400
iceman400's Avatar
k thanks..i will try that tomorro!.. what do you mean by a shim or two?.. would a shim prevent it from sliding off?
Connor.
Old 03-12-2008, 02:07 AM   #4 (permalink)
lowbudget
Mountain Man
lowbudget's Avatar
A shim as in spacing it out. It won't hold it on. Unless it's a rusted/welded together mess LOL. Then it might cause it to stick a little bit. You will want to keep track of them in case you need them to square up new clutches.
lowbudget is offline   Reply With Quote
Old 03-12-2008, 08:10 AM   #5 (permalink)
iceman400
iceman400's Avatar
Oh ok i see.. ok thanks for the tips!
Connor.
