metal shavings on chaincase dipstick - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 02-06-2008, 06:50 PM Thread Starter
I checked my oil in my chaincase and there were matal shavings stuck to the magnet on the dipstick. I know the magnet is there to catch the metal shavings but is this normal? Do I need to take it apart and investigate further or just keep riding?
highcountry is offline
post #2 of 11 (permalink) Old 02-06-2008, 06:58 PM
maineack bob's Avatar
depending on the size of the shavings it could be normal or abnormal but usually there isnt supposed to be shavings on it, there is just usually a bit of metal flake. if it was me i would take the side of the chain case off ASAP and check the internals (sprockets and chain) of it for serious wear it could also be from a berring let go but you should feel it if it was the berring or atleast hear it riding rough.
2000 Summit 600 Silver with Yellow and Red accents...'86 Toyota Supra Ractive Exhaust, and soon to be introduced to a toyota C26 turbo ...'80 AMC Eagle 4X4 L6 4.2l...'91 Tracker 3" lift and 31's
maineack bob is offline
post #3 of 11 (permalink) Old 02-06-2008, 07:54 PM
IndianRvrShiver's Avatar
I am sure the engineers expect to have some metal shavings or else they would have saved the money for a magnet!! Wouldn't hurt to pull it apart, tho!!
IndianRvrShiver is offline
post #4 of 11 (permalink) Old 02-06-2008, 10:03 PM
iceman400's Avatar
i changed my chain case oil last season for the first time since new and there was very small sparkles on metal..puled the cover and everything was good!... so i would pull the cover and investigate further JUST in case,.. its probably nothing..just a bit of wear or somthing
2001 Machz 800 spring order yellow
1998 ski-doo mxz 440
1998 Jeep grand cherokee 5.9
1966 Dodge Charger-BAD ASS
iceman400 is offline
post #5 of 11 (permalink) Old 02-08-2008, 01:02 PM
jkust's Avatar
I had the same issue with some small shavings on my 98 GT dip stick. I was a little panicked until I realized even the manual says some shavings are normal on the magnet. After a lube change, I have yet to see another shaving. I am pretty sure that my changing the lube at 2500 miles was the first change of its life. The fluid was almost like peanut butter.
jkust is offline
post #6 of 11 (permalink) Old 02-08-2008, 03:36 PM
Shavings are normal, chips are not. Change the lub every 1000 miles or once a season.
Morsnow is offline
post #7 of 11 (permalink) Old 02-08-2008, 08:37 PM Thread Starter
I'm going to change the oil tomorrow. My sled has reverse and the crankcase doesn't look the same as my manual shows. Is there still a oil fill bolt so I don't overfill the chaincase and also is there any other precautions I need to take when the cover comes off since it has the reverse gear?
post #8 of 11 (permalink) Old 02-11-2008, 08:16 AM
What kind of sled is this?
Morsnow is offline
post #9 of 11 (permalink) Old 02-11-2008, 01:16 PM
~SUPER USER~
cvanmarter's Avatar
Clean lube once a year you'll never go wrong
cvanmarter is offline
post #10 of 11 (permalink) Old 02-11-2008, 03:20 PM Thread Starter
The sled is a 98 mxz 500. I opened the chaincase up and everything looked good. I used polaris synthetic chaincase lube to fill it up because the polaris dealer is the closest to my house.
post #11 of 11 (permalink) Old 02-11-2008, 04:36 PM
The synthetic oil from Polaris should be fine. Yamaha is the only one still using Gear lub.
Morsnow is offline
