Old 05-04-2008, 05:34 PM   #21 (permalink)
jnugent4
jnugent4's Avatar
Whats this blue stuff
here are a couple of other pics. See picture of blue stuff maybe antifreeze in crank case of bad piston which failed. I also drilled a hole at a slight angle which exits between the two front bearings hopefully to lube the PTO bearing. The hole was around 1/8 inch hopefully it will be big enough to lube the bearing. I put ISOFLEX grease in there as well just to be sure. There was already a larger hole there which appeared to lube the second bearing from the front.
96-formula-iii-600-engine-failure-skidoo-failure-003smaller.jpg  96-formula-iii-600-engine-failure-skidoo-failure-016smaller.jpg
Let it Snow Let it Snow Let it Snow
Polaris 2004 Trail Touring edge
Skidoo 96 Formula III LT
jnugent4 is offline   Reply With Quote
