Whats this blue stuff
here are a couple of other pics. See picture of blue stuff maybe antifreeze in crank case of bad piston which failed. I also drilled a hole at a slight angle which exits between the two front bearings hopefully to lube the PTO bearing. The hole was around 1/8 inch hopefully it will be big enough to lube the bearing. I put ISOFLEX grease in there as well just to be sure. There was already a larger hole there which appeared to lube the second bearing from the front.
Let it Snow Let it Snow Let it Snow
Polaris 2004 Trail Touring edge
Skidoo 96 Formula III LT
