Old 02-25-2004, 09:04 PM   #1 (permalink)
johnmcneilly
1995 mach z burn down need help
hi
i am new to this list and it looks like there is some mach z peps here.
i just burnt down my 780 so i am trying to redo it again after 150 mi's OUCH yep it hurts and still hurts
i dont know what base gasket to try now the sealer says there is 3 3mm 4 m 6 mm and they also said i can run a 3 mm and a 4 mm to make 7 mm
so i am stumped i dont know why it burnt down because it was fouling plugs earler in the day but i was going over 100 mph when it burnt down you machz lovers i love this sled but it is getting costly i am going to get a set of egt gauges before i run it again
one more thing last year it had crank seals done what should i do ???
thanks john mc
run them hard or dont run then at all
johnmcneilly is offline   Reply With Quote
Old 02-26-2004, 01:35 AM   #2 (permalink)
Taz Man
What kind of oil
What kind of oil are you using? I was told to only use synthetic oil in the 780. Also what plug and gap, was it too hot? I just got mine so I want to know what to do to make things last. I was told to use 92 octain fuel it helps it run cooler. What type of gauge are you getting and what does it do? Good Luck with every thing...
Taz Man is offline   Reply With Quote
Old 02-26-2004, 08:33 PM   #3 (permalink)
johnmcneilly
i was running 92 oct. fuel and castrol sent. oil stock ngk plugs br9es dont run it over 100 mph and it prob will last .everyone i talk to tell me the same thing.but you will go through alot of plugs in the mach z 780 i am going to get exhaust gas temp . gauges and put them in the exhaust pipes if it gets to hot i will have to back off the gas. 1300 deg. is melt down so i was told 1000 to 1200 deg. is ok. this will help me jet the carb too.when i fowl a plug i wont have to look for it also i just look at the gauge that is cold.
i might get a dial a jet also for on the fly jet adj.ment
