93 670 into 95 Summit 670
I read a post somewhere on a 93 670 to a 95 583 swap that the 93 ingnition and tach have to be used due to the 93 being a 4 pin and the 95 being a 6 pin or vica versa. I'm assuming the 95 670 will be the same. If it is can I swap out stator and pick up from the 95? Will it all bolt up? I'm at work in Kuwait and want to know if I need to be watching E-bay for the parts.
