Old 01-28-2008, 11:26 PM   #1 (permalink)
drew b
sled dead on trail
Was out for about 45 minutes on my 2000 380 Touring E and it died. Luckily someone came by and towed me home. It was about 29 or so degrees out. I have spark and can smell gas. Turns over but won't fire up. I sprayed "Quick Start" into one of the spark plug holes, but still would not fire up. When I turn it over, the lights come on. I changed both spark plugs on the trail, but that did not help. Any ideas??
1970 ski doo olimpique
1999 Yamaha Vmax
2000 ski doo touring E
drew b is offline   Reply With Quote
Old 01-29-2008, 03:12 AM   #2 (permalink)
lrnnorth
Above The Arctic Circle
lrnnorth's Avatar
To have a running motor you need 3 things: Proper fuel/air mixture, Strong spark, and good compression. Is your spark strong? What is your compression?
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 (The TANK)
Out Of Commission Till Next Year
lrnnorth is offline   Reply With Quote
Old 01-29-2008, 07:06 AM   #3 (permalink)
Was it running, then just died? Or did it start losing power?
Old 01-29-2008, 07:59 PM   #4 (permalink)
drew b
It was running fine and then just stopped, the motor stopped and I glided to a stop, all within about 5 seconds
1999 Yamaha Vmax
Old 01-29-2008, 08:10 PM   #5 (permalink)
Check spark with an inline neon tester, just to be sure. Then do a compression test. It should be 120 psi or higher.
Old 02-04-2008, 08:31 PM   #6 (permalink)
drew b
fuel filter or choke?
This past weekend, I checked the fuel lines and fuel filter. I took off (what I believe to be) the fuel filter that is on the end of the fuel line in the gas tank (brass unit with mesh and a spring wrapped around it) and it seems to be fine, but after I removed it, I got the sled to start. The fuel filter looks to be in fine shape and the ball-bearing inside (which I think is to keep the gas in the line) seems to work fine. I replaced the choke cable a week or so previous, so do you think it might be the fuel filter or could I be having issues with the way I set up the choke? Once I replaced the choke cables, I have made several short runs but could the sled be "flooding" with the way the choke is set? Is is ok to replace the old fuel filter just with a inline plastic fuel filter or should I spend the $15.00 or so vs the $2.00.
I started the sled again tonight, but to keep it going until it warms up, I have to choke it and apply the throttle, then once it starts, have to feather the throttle to keep it going.
thanks
1999 Yamaha Vmax
Old 02-04-2008, 10:50 PM   #7 (permalink)
skioodozie
skioodozie's Avatar
Sounds like you might have a compression problem. do a leakdown test after the engine warms up.
skioodozie is offline   Reply With Quote
Old 02-05-2008, 05:55 AM   #8 (permalink)
Clean the carbs.
If you have to keep choking it or tickle the throttle to keep it running at idle, the idle circuit is partially clogged.
