Originally Posted by smallengineguy
Have you tried a higher wattage bulb yet?
When I am on the throttle, it is more than bright enough... its just that when I'm idling, or moving a low rpm (which is rare, but does happen), it goes very dull. The biggest issue that this comes into effect is when I am taking a sharp turn... i let off the throttle to slow down, but then i can barely see where the trail is around the bend. I actually enjoy night riding quite a bit, and would just like to keep the headlights bright. I did some poking around today and did find out that my headlights are currently A/C voltage. I wired in a switch so I can turn them on/off at will, and also wired up some LED's inside the cowling so they shine through all of the air vents... but without a single visible LED. Once I get the under lighting on, I will post up some pics, but it really does look quite nice.
Thanks for the advice.
Kenny
