Look at the limiter strap on the front of the skid, it should have about 1/4 in of slack as a minimum.
Check if there is any adjustment to the coil over shock that will be there. If there is none, you can shorten the limiter strap to put more weight onto the skis.
My preference would be to lower the rear skid mount to the bracket just below the running boards (if it has them) as this will achieve the same effect and still give some kick back travel to the front of the skid.
Also, you might need new skegs first. Maybe get ones with a longer carbide section too.
I have 6" 60 Degree Woody's on mine and it steers like it is on rails.
