Old 01-25-2008, 08:23 AM   #1 (permalink)
maineack bob
maineack bob's Avatar
'00 summit track skips sometimes
so i finally managed to get a sensible ride on my sled and ive knodesed that if you pin it in powder/loose snow or you pin it and she hooks in shell skip on the track sprokets 5 or 6 times then hook in, im shure it probobly just the track wants to be tightened up but i wanted to know if anything else would cause this because the track dosnt look that loose when you lift the skidoo up also the track is brand new and the sprockets look in great shape...how tight should the track be as in how far should it be hanging down from the slides when you pick her up ive been told about an 1 1/4" hanging down but that was for a 121" track and my skidoo has a 136"
P.S. i have been reading around and there should be a proper spec of how mught weight and ho much sag with that weight on the track but i have no idea what that is any help would be appreaceated
2000 Summit 600 Silver with Yellow and Red accents...'86 Toyota Supra Ractive Exhaust, and soon to be introduced to a toyota C26 turbo ...'80 AMC Eagle 4X4 L6 4.2l...'91 Tracker 3" lift and 31's
maineack bob is offline   Reply With Quote
Old 01-25-2008, 11:54 AM   #2 (permalink)
maineack bob
Question
ok im pretty shure now that the track is the problem after a short ride it was hangin down about 1.75"...its a brand new track with about 100 - 200 km on it so it must have streached and i have also figured out that i should hang a 16lb weight on the track to check the the tension but i dont know how much space should be between the track and the hifax with that weight on there...
Old 01-25-2008, 12:18 PM   #3 (permalink)
1" or slightly less.
Old 01-25-2008, 01:48 PM   #4 (permalink)
maineack bob
ok thanks... so just to be shure that is about 1" gap with the 16lbs hanging from the track or is that 1" without the 16lbs?
Old 01-26-2008, 02:37 AM   #5 (permalink)
with the weight.
