Old 01-22-2008, 10:53 PM   #1 (permalink)
DanE
580 ideals to fast
i have a 94 skidoo grand touring 580 it ideals to fast around 3500 rpm how do you slow it down ? what speed should it run ? thanks
DanE is offline   Reply With Quote
Old 01-22-2008, 11:06 PM   #2 (permalink)
polaris punk
The first thing to check is the idle setting on the carbs. chances are they need to be turned down. Also check the rubber boots on the carbs for cracks.Replace them if they are cracked.
polaris punk is offline   Reply With Quote
Old 01-22-2008, 11:19 PM   #3 (permalink)
DanE
are the ideal scews the one's on the side or top of carbs? thanks
Old 01-23-2008, 12:51 AM   #4 (permalink)
TheBackRoads
TheBackRoads's Avatar
idle**
and welcome to the site!
Gots me a sled!
2003 Polaris XC500!
TheBackRoads is offline   Reply With Quote
Old 01-23-2008, 01:04 AM   #5 (permalink)
RedRider_AK
Know-it-all hooligan
They're the "grippy" looking screws you can turn with your fingers, on the side of the carbs.
Originally Posted by RedRider_AK
If any of my friends heard me say that, they'd call me Gramps or something
Originally Posted by IndianRvrShiver
That line should be in your sig!!
RedRider_AK is offline   Reply With Quote
Old 01-23-2008, 09:48 AM   #6 (permalink)
Idle at 1500/2000 rpm.
Old 01-23-2008, 11:54 AM   #7 (permalink)
DanE
thanks turned the screws out have it idealing at 1500 to 2000 rpm
Old 01-23-2008, 12:46 PM   #8 (permalink)
JheLrey
JheLrey's Avatar
Your first problem is you POSTED THIS TWICE! Start with one... I bet you are impatient, that could be part of your problem...
Old 01-23-2008, 07:42 PM   #9 (permalink)
zipper670
zipper670's Avatar
Moving my idle screw does not really do much, how much do you have to move them, a lot? My sled is idling around 1200, I don’t think it’s really hurting it, is it, I would rather move it up a little. Any suggestions?
zipper670 is offline   Reply With Quote
Old 01-23-2008, 09:20 PM   #10 (permalink)
DanE
i have them turned out 4-1/2 turns a 1/2 turn seems to change mine a lot
Old 01-23-2008, 09:23 PM   #11 (permalink)
DanE
i tried mine 1/2 a turn at a time then started it to see how much it changed the speed until i got it to where i wanted it
Old 01-24-2008, 06:17 PM   #12 (permalink)
zipper670
zipper670's Avatar
Does turning it out raise or lower the idle?
Old 01-24-2008, 07:19 PM   #13 (permalink)
Skligmund
Alaskan Member
Skligmund's Avatar
Depends on which way you turn it. You may have some dirty carbs though, and you should consider cleaning them.
1980 Polaris TX-L 340 - Stock
Skligmund is offline   Reply With Quote
Old 01-24-2008, 08:38 PM   #14 (permalink)
DanE
turning them out lowers the speed
