i own a 04 mxz-x 600 ho sdi . the track on my skidoo atm is a 121 , 1 1/4 paddle track. i was wondering if i could get a ripsaw track with a bigger paddle on it ? whats the biggest i could go in a lug ?
check your current clearance in the tunnel. you could go 1 1/2 most likely, may have to keep anything larger really tight to prevent it from ballooning into the heat exchangers.
thanks for reply ... i thought about same thing . prob around 1 1/2 .. would i find much difference though in going from a 1 1/4 with 120 studs (not quite sure if it is but i know theres studs) and then puting on a 1 1/2 ?
