Old 01-16-2008, 07:11 PM   #1 (permalink)
evans
Newbie Rider
Fuel Problem
hey guys, I have a FIII 600, but the newly rebuilt thing will not start on its on. The only way I can get it to start is by pooring a little gas down the cyclinders. I can see the gas through the lines that go to the carb. Do I have to adjust the screw? The carbs are in sinc and open and close all the same, but the engine just doesnt not get the gas.. any help?
1996 FIII 600 - custom painted hood(black), more coming..
197? Merc Hurricane 440- classic two head and tail lights
1991 Honda Civic HB- current project
1987 Ford Ranger 4x4- 3 inch body lift
1994 GMC Jimmy- Currently Driving Hard
evans is offline   Reply With Quote
Old 01-16-2008, 08:14 PM   #2 (permalink)
Are the chokes opening when you pull the lever up?
Old 01-16-2008, 08:56 PM   #3 (permalink)
SkiDooFormulaMX
GO GREEN OR GO HOME!
SkiDooFormulaMX's Avatar
stupid question but you did put on the lines at the bottom of the bowl so the fuel just doesnt run out before you put the carbs back on correct? only reason i ask is ive been there done that.
2003 ARCTIC CAT ZL 600 EFI SS-2700 MILES-GETTING SOME MILD TWEAKING THIS SUMMER
2002 ARCTIC CAT Z 440 ES-622 MILES-MINT, JUST LOOKING FOR SOME STUDS AND FATBOY TORSIONS.
1997 ARCTIC CAT EXT 580 EFI DLX 4000 MILES-SOLD 8/08
1998 ARCTIC CAT ZR 600 EFI-3700 MILES-BUILT-SOLD-9/07
1996 INDY CLASSIC 500 ESR-5100 MILES-SOLD 4/08
1987 SKI DOO FORMULA MX 470-12000 MILES-SOLD 12/07
SkiDooFormulaMX is offline   Reply With Quote
Old 01-16-2008, 10:10 PM   #4 (permalink)
evans
Newbie Rider
well I got it started, but only with the choke on. Once it starts I take the choke off and it runs for 30 seconds than dies out. Any suggestions? Also there is a clicking sound, mayb the clutch?
Old 01-17-2008, 07:26 AM   #5 (permalink)
Remove the fuel lines from the carbs. Pull it over and see if fuel is coming out of the lines. If it's just barely dribbling out, there is a problem with the pump, tank, or the required vacuum to get the pump to work correctly.
Old 01-17-2008, 09:30 AM   #6 (permalink)
evans
Newbie Rider
alright thanks for the suggestions, definately try it tonight
Old 01-17-2008, 05:40 PM   #7 (permalink)
evans
Newbie Rider
well i checked to make sure there was a good amount of gas goin to the carbs and there seems to be. So I am going to clean the carbs tonight and see what happens.. any other suggestions?
Old 01-17-2008, 06:44 PM   #8 (permalink)
upersleder
upersleder's Avatar
take the pilot jets out and make sure they are clean. air screws out 1 1/4 turn each.
2003 MXZ 700X
Old 01-17-2008, 11:03 PM   #9 (permalink)
evans
Newbie Rider
air screws you mean the big ones on the side?
