01-14-2008, 11:57 PM
Newbie Rider
Fuel Lines
hey guys, just picked up an 96 FIII 600. I have rebuilt the engine, put it all in and hooked up except a few things.(got the sled already torn apart). I know the bigger fuel lines come from the fuel pump to each carb. One line comes in from the gas tank, and another comes from the fuel pump to the crank case. Is this all there is? Also the throttles. I have each throttle cable hooked up, same with the choke cables, but there is one extra one left over. It has a cable showing at the end. What is this for? Where does it hook up?
Any help with this will be greatly appreciated. Young guy just getting into sleds, first build of mine ever. Thanks for any help
01-15-2008, 12:51 AM
That third cable probably goes to the oil pump.
01-15-2008, 07:33 AM
RJ's right. Make sure you hook that up!
01-15-2008, 09:02 AM
Newbie Rider
that should hook up by the third carb right? or the pulley case?
01-15-2008, 01:25 PM
Below the carbs, directly between them.
01-15-2008, 02:21 PM
Newbie Rider
on the bottom of the engine? between which of the three carbs?.. wow sounds bad but this is the only problems I have before I get it going tonight.
1996 FIII 600 - custom painted hood(black), more coming..
197? Merc Hurricane 440- classic two head and tail lights
1991 Honda Civic HB- current project
1987 Ford Ranger 4x4- 3 inch body lift
1994 GMC Jimmy- Currently Driving Hard
01-15-2008, 05:44 PM
Newbie Rider
bump, really need to get this done.. where does that cable hook up, and another question is how do i get my throttle cable at the handles to not be so slack and work better?
01-15-2008, 08:27 PM
The last cable hooks to the oil pump, which can be found by following the line from the oil tank, it goes right to the pump. There is a lever on the pump that the cable goes to.
01-15-2008, 08:59 PM
Newbie Rider
ok sounds good, I am pretty sure I can find that. Do I have to bleed it or anything before/after hooking it up? Also how do i get all those cables tight again at the throttle?
01-16-2008, 12:39 AM
Newbie Rider
ok thanks guys have it all hooked up and she was ready to fire until I ran into another problem. Does the fuel tank have a filter in it? I have no fuel coming out of the tank because all the lines are dry. Any suggestions on how to solve this problem or easiest way?
01-16-2008, 04:26 AM
Try making a good seal on the tank filler hole and blowing into the tank, this will force fuel up to the pump to help get it going.
01-16-2008, 10:18 AM
Or the line is gone in the tank. You should hear bubbles, if not, time to pull the line out of the tank. It is amazing how many sleds I picked up and that was the only problem!
01-16-2008, 02:02 PM
Newbie Rider
thanks for the help guys, had it all going good, than carbs started leaking because I forgot to put the gaskets on haha, oops.. but it should be running good tonight than only clutch is left
