1997 skidoo formula III 600 - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 14 (permalink) Old 09-18-2007, 06:16 PM Thread Starter
oldesledupes
Hey all,
I just picked one of these up with a couple of bad crank bearings. Been looking around on the net and seems like a lot of guys had problems with the cranks in these sleds. anyone know if the motors are any good in these sleds? hows the rest of the sled?
thanks,
josh
oldefuckinsledupes
75 arctic cat el tigre 440
76 arctic cat el tigre 5000
78 john deere liquifire 340
94 yamaha vmax 600
97 skidoo formula III 600 triple
oldesledupes is offline
post #2 of 14 (permalink) Old 09-18-2007, 07:36 PM
littledawg's Avatar
i heard they where nice sleds. but you realy need to talk to seg,small engine guy he knows hes ski doos.he will help ya
06 700 fusion98xc700 06 500 indy
go fast or go home
littledawg is offline
post #3 of 14 (permalink) Old 09-19-2007, 06:42 PM
upersleder's Avatar
get the crank re-done, the rest is good, there is a hole you should drill in the upper case half to aid in lubrication to the outer PTO bearing. make sure everything is done correctly and enjoy
2003 MXZ 700X
take the warning labels off everything and let the problem sort itself out
upersleder is offline
post #4 of 14 (permalink) Old 09-20-2007, 07:49 AM
Yup, what uper said. There was a fix for the lack of oil to the bearing by drilling the case.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #5 of 14 (permalink) Old 09-20-2007, 10:19 AM Thread Starter
oldesledupes
thanks for the replys guys. I'll prolly be asking you some questions about drilling the case when I go to do it.
oldefuckinsledupes
94 yamaha vmax 600
post #6 of 14 (permalink) Old 09-20-2007, 04:00 PM
GO GREEN OR GO HOME!
SkiDooFormulaMX's Avatar
what did ya pay for it? i almost got one before i found the cat.
2004 F7 SNO PRO 3853 MILES, ODS CLUTCHING, GEARED, BMP PIPE, D&D Y PIPE, SLP INTAKE
2003 F5 STANDARD 2201 MILES
2002 Z440 ES 2650 MILES
SkiDooFormulaMX is offline
post #7 of 14 (permalink) Old 09-21-2007, 08:59 AM Thread Starter
oldesledupes
I paid $650 for it. so far, but prolly not, it looks like all it needs is a crank and some rings.
do you guys know where I drill the upper case? once I drill the case do I run another line off the oil pump over to the new nipple? or do you know a website where I can get this info.
thanks,
josh
oldefuckinsledupes
94 yamaha vmax 600
post #8 of 14 (permalink) Old 09-21-2007, 07:04 PM
upersleder's Avatar
when you have the thing apart, look down on top where the cylinder goes on. on the PTO side there will be a machined spot where there looks like there should be a hole. get the drill out and drill a 3/16" hole but you must aim it to end up with the hole between the two bearings. then clean and de-burr the hole. thats all you need.
2003 MXZ 700X
post #9 of 14 (permalink) Old 09-21-2007, 08:36 PM Thread Starter
oldesledupes
thanks again, you guys on the forum saved my ass again, prolly would have ended up burning out my new crank if I wouldn't have heard about this through you guys.
I can see on the case where to drill, so once I get that setup I just run another line off the oil pump?
oldefuckinsledupes
94 yamaha vmax 600
post #10 of 14 (permalink) Old 09-22-2007, 12:45 AM
upersleder's Avatar
NO its inside the motor, oil/gas mix just gets in there and lubes the bearing.
2003 MXZ 700X
post #11 of 14 (permalink) Old 09-22-2007, 09:28 AM Thread Starter
oldesledupes
sorry uper, i'm alittle slow. I see what you mean now, on the inside of the case and drill at a bit of an angle outwards to get between the bearings. the spot directly above the bearings on the outside of the case was what I was orginally looking at/close call. I see there's another one of these spots to drill on the inside of the mag side of the case, should I drill this one too?
oldefuckinsledupes
94 yamaha vmax 600
post #12 of 14 (permalink) Old 09-22-2007, 08:50 PM
Couldn't hurt.
post #13 of 14 (permalink) Old 09-23-2007, 08:25 PM
upersleder's Avatar
no, only a single bearing on the mag side, will just trap oil and most likely get into the ign system.
2003 MXZ 700X
post #14 of 14 (permalink) Old 09-23-2007, 09:50 PM Thread Starter
oldesledupes
thanks, i'll just drill the pto side then
oldefuckinsledupes
94 yamaha vmax 600
