Old 12-29-2006, 07:58 PM   #1 (permalink)
rvanderklok
rvanderklok's Avatar
1985 467 Liquid possible problem???
Fired up the old Doo today, and when I started it, the Oil light was on, and the Tach was bouncing between 0 and 1000 rpms. I hit the brake, and the oil light went out after I released the brake lever. Shut the machine off. Started it 10 min later, and tach worked fine and oil light only came on when I hit the brake lever....so all seemed fine.
Does this sound like a possible intermittent oil pump problem? Or just a freak thing?
Also, how many gal. of gas does the tank on an 85 Formula MX 470 hold?
thanks
Get on, sit down, shut up, and HANG ON!!!
rvanderklok is offline   Reply With Quote
Old 12-30-2006, 12:08 AM   #2 (permalink)
upersleder
upersleder's Avatar
sounds like you had a bit of an electrical glitch, maybe the brake switch was sticking. just keep an eye on it, not suew on the gas capacity
2003 MXZ 700X
Old 12-30-2006, 12:16 AM   #3 (permalink)
jagermiester
jagermiester's Avatar
Maybe a dual purpose light? I had a 95 Mach 1 that when you hit the brake the red light would come on as an indication the the brake light was working. Light would not come on when the tail light was burned out or removed. The red light was also an indicator that the oil level was low. Maybe you had a sticky brake switch when you first started it. Just a guess but I think it may hold 10 galllons of fuel.
98 Jag (for the kids)
03 MXZ-X 800 (Blair Morgan)
Old 12-30-2006, 12:39 AM   #4 (permalink)
upersleder
upersleder's Avatar
on ski doo the oil light comes on with the brake, nothing wrong there. his problem was it was on without him hittin the brake i believe....
2003 MXZ 700X
Old 12-30-2006, 07:43 AM   #5 (permalink)
Probably brake switch was skittish at first. Holds roughly 8 gallons.
Old 01-01-2007, 12:46 PM   #6 (permalink)
rvanderklok
What scares me, is the fact that the tach was bouncing between 0 and 1000 rpm, and doesn't the tach run off the oil pump? The sled idles at around 3000 rpm when it's cold, so the needle only bouncing as high as 1000 rpm is definately not normal. I could understand if the sled idled really low, but it doesn't.
Old 01-01-2007, 12:48 PM   #7 (permalink)
upersleder
upersleder's Avatar
the tach is completely electrical, has nothing to do with the oil pump
2003 MXZ 700X
Old 01-01-2007, 02:01 PM   #8 (permalink)
NOt connected in any way to the oil pump. You may have a grounding problem with the tach.
Old 01-01-2007, 07:17 PM   #9 (permalink)
rvanderklok
Ok, thanks....I'm used to Yamahas where the tach runs off the oil pump. I feel better now.
