12-20-2006, 01:02 AM
Changing Jackshaft
I want to change the jackshaft on my 1995 Mach-Z. The clutch side bearing went out and caused damage to the original. I found a good used jackshaft on e-bay. Is there any tips,info. or special tools needed.I haven't had time to look at it, I hope to get to it this weekend. Thanks.
12-20-2006, 01:10 AM
That's the easy one to change. Remove the secondary and unbolt the keeper flanges and unlock the cam.
You can do this with the shaft in the sled.
12-20-2006, 12:01 PM
yea, its easy, besides what RJ said you will need to take the chaincase cove off and take the nut off the other side. slide the old one out and the new one in.
2003 MXZ 700X
12-20-2006, 11:25 PM
Thanks for the advice, I was hoping it would not take too long or special tools. I'll get on it this weekend I am going to change brake pads while i am at it. Any guess on the cost of brake pads?
12-20-2006, 11:28 PM
2003 MXZ 700X
12-21-2006, 06:19 PM
Back Out!
Your gonna need a pair of snap ring pliers, not really a "special" tool, but not everyone has one
96' Formula III 600 triple
02' XCSP 800 edge
12-21-2006, 06:32 PM
not if he slides the jackshaft out of the bearing. you just need it if you want to get the bearing out of the case.
2003 MXZ 700X
12-21-2006, 07:33 PM
Back Out!
You'd assume he'd replace it, or atleast repack it
02' XCSP 800 edge
12-21-2006, 11:31 PM
its lubed with the chaincase oil, no grease. but yes by all means it should be checked and replaced if needed
2003 MXZ 700X
12-22-2006, 12:17 AM
I do have snap ring pliers, and will make shure to check the be shure to check the chaincase bearing.What about the brake pads do I need to remove the chaincase to get at the inner pad?
12-22-2006, 12:22 AM
shouldnt have to. pads will either lift out of the caliper or you will have to take the caliper off. i havent had to change a set of pads on any of my sleds, only know of one person that has and i have no clue as to why he burned them up so fast.
2003 MXZ 700X
12-23-2006, 12:12 AM
I'll look at them and if they are in speck 1mm. or more I will leave them as is. They are probably just fine. thanks for all the help
12-23-2006, 12:38 AM
Wants to see snow
I would like to know that I have more than 1mm of brake bad on my sled. That seems a tad thin to me. I'd rather see something more like 1 cm but at least 5mm.
Just my opinion.
84 srv 540 starting to mod
98 indy classic xlt 600
LET ME OUT OF THE HOUSE
12-24-2006, 01:55 AM
I think he means 1mm of wear or less.
01-04-2007, 11:14 AM
Cook and bottle washer
We just did an 02MXZX 800 with no problems. Save yourself a lot of grief and go to the BRP website so you can see the parts layout. The lower driveshaft is a pick of cake, the upper( off the secondary) requires a bearing to be pulled (6 inches in) and repressed. Good luck, it's not a bad job.
2004 Viper- Mine
2002 MXZ 800- Mom's
2002 MXZX 800- the kids
2003 XCSP700-the kids
1996 Suzuki 300 King Quad-MINE!
1996 Yukon.Mine ..maybe.
1999 Pathfinder.
Work is for those who don't hunt,fish,boat,sled and/or ATV
