Old 12-07-2006, 02:55 PM   #1 (permalink)
z085688
z085688's Avatar
Unhappy Mach 1 Problems Please Help!!
I have a 97 mach 1. Recently I took the carbs off and cleaned them and put them back in. I had it running for a while and now about a week later i can't get it started at all. Every time i try to start it and it doesn't work i take the plugs out and they are all wet. I clean them with carb and choke cleaner dry them off and put them back in. (They are last seasons plugs.) but it still doesn't start. I'll leave the plugs out and pull it over to see that i do get spark. It just seems like every time i put them in the sled they get to wet to fire when i pull it over. Any ideas would be greatly apprecited.
z085688 is offline   Reply With Quote
Old 12-07-2006, 03:56 PM   #2 (permalink)
headbanger7483
headbanger7483's Avatar
could u be getting to much gas and flooding it?
I BLEED GREEN
2002 ARCTIC CAT ZR 500
1999 ARCTIC CAT ZL 500efi
1993 SKI DOO MACH 1
headbanger7483 is offline   Reply With Quote
Old 12-07-2006, 03:57 PM   #3 (permalink)
Put NEW plugs in it. Did you reset the float heights, etc when you cleaned the carbs?
Old 12-07-2006, 04:04 PM   #4 (permalink)
tripletriple
tripletriple's Avatar
Try putting new plugs in. I wouldn't be surprised if it fires right up. You may have fouled the plugs
2008 Ford F150 FX4 Plus SuperCrew 5.4L V8
2005 Ski-Doo MXZ Adrenaline 600 HO
2000 Bayliner Capri Bowrider 20' 220HP 5.0L Merc I/O
tripletriple is offline   Reply With Quote
Old 12-07-2006, 04:24 PM   #5 (permalink)
z085688
z085688's Avatar
what do you mean reset the float heights? I'm sure i didn't though. all i did was take them apart, spray them with carb and choke cleaner and put them back together. Also most of the gas is from last season. I put about five gallons of new stuff in recently, should i drain the tank and put all brand new gas in.
Old 12-07-2006, 04:46 PM   #6 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
Won't hurt to have good fresh fuel!! Drain the old stuff out & put it in your car....no wasted gas that way!!
Old 12-07-2006, 05:11 PM   #7 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
Next time you have your carbs apart, don't just spray them with carb cleaner. Clean out the main jet, set the floats, and make sure the needle valve is seating and releasing properly. Also stabilizing your gas in the spring will help it fire up in the fall. New plugs are a must.
Old 12-07-2006, 08:20 PM   #8 (permalink)
Use compressed air to blow out all the holes, jets, etc in the carb also.
Old 12-08-2006, 02:34 AM   #9 (permalink)
z085688
z085688's Avatar
Thanks, hopefully I'll put the new gas and plugs in and be able to hit the trails this weekend.
Old 12-20-2007, 11:28 PM   #10 (permalink)
yellowf4
What did you mean about setting the float heights in this post???
When I look at the microfiche of this carb, it looks like the little post on the float is supposed to be down...is that right? I've never heard of setting the float height.
yellowf4 is offline   Reply With Quote
Old 12-20-2007, 11:36 PM   #11 (permalink)
jagermiester
jagermiester's Avatar
With the bowl off, turncarb upside down. When the float is at rest it should be parallel with the carb body. If it is not you must bend the tab until it is. When it is apart and you are looking at it you will see how it works.
98 Jag (for the kids)
03 MXZ-X 800 (Blair Morgan)
