Is the smoke from the belt by chance? Did your filters get iced over? Brake locked up? Actual y w/the high comp. readings I think You may have dislodged a nest in the exhaust and then it pluged up solid down the line the smoke has to come out somewhere. The more you push it the more backpressure you get there
"The sled will top out between 45-60 MPH with a lot of smoke coming out from the vents in the hood."
Just a thought with the limited info we have
84 srv 540 starting to mod
98 indy classic xlt 600
LET ME OUT OF THE HOUSE
